First post, by Robin4
- l33t
Hello dear vintage computer users,
I have two chaintech SLD / SLP motherboards here.. One have an Voltage regulator onboard, so it would also support 3,3 volt cpu..
The other one doesnt, but i have plans to mount one on that other board too, just only wait when i have a good desolder station..
I had already played with that board, but actually i cant go further then the tested 100mhz cpus..Maybe 120mhz will also do..
But got some problems when setting up the board.. I red on a website, when the board supports DX4 processors, it also will do the raw AMD 5x86 - p75-133mhz cpu.
But maybe i dont known this board well.. I like to know which settings i do have to configure those motherboards..
Its seems it can handle:
80486DX4 as this manual says: http://museum.ttrk.ee/th99/m/C-D/33003.htm (cant find more then anything more like DX2, P24S or P24D or pentium overdrive on the sheet on the PCB from those motherboards)
I really like to know which settings i need to set those motherboards..
