First post, by janskjaer
- Member
I'm not getting any audio from the game's CD when the game is running. I can see that the CD is playing it (the CD activity is spinning at a steady pace), but I'm only getting game sound effects from the sound card.
I've loaded my CD driver and MSCDEX v2.23 in the AUTOEXEC.BAT and CONFIG.SYS files as shown below:
[Extract from AUTOEXEC.BAT]
PATH=C:\;C:\DOS;C:\SOUND\AWE32C:\DOS\MSCDEX.EXE /D:MSCD001C:\DOS\SMARTDRV.EXE /XSET CTCM=C:\SOUND\AWE32SET SOUND=C:\SOUND\AWE32C:\SOUND\AWE32\CTCM.EXEC:\SOUND\AWE32\AWEUTIL.COM /S
[Extract from CONFIG.SYS]
DEVICE=C:\CDROM\VIDE-CDD.SYS /D:MSCD001 /P:1F0,14 /P:170,15 /P:1E8,12 /P:168,10DEVICE=C:\SOUND\AWE32\CTCM.EXE
When running the game under Windows 95's DOS mode, I also don't get the audio. However, if I run the game in Windows 95, I do hear the CD audio playing. What am I doing wrong? Obviously MSCDEX isn't to blame as it loads correctly in all situations. Could it be the DOS driver I am using to load the CD? Or the SB16/AWE32's configuration isn't correctly set to utilise MSDCEX?
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
