First post, by ibm5155
Hey, Does someone know what's the best driver for voodoo 3?
also, I have a problem with the latest official driver (10700) and Colin McRae Rally 2, after 15 seconds playing the game it freezes, and I readed somewhere that it was a problem with the driver, so wich one should I use ? (official or modified)
And last question, how can I play pod with 3DFX support? I got pod with the maxi sound cd install but I can't play it '-'
Reply 1 of 4, by NitroX infinity
Maybe you need a patch for POD?
http://www.thebasingers.com/0706milbs/pod/
NitroX infinity's 3D Accelerators Arena | Yamaha RPA YGV611 & RPA2 YGV612 Info
Reply 3 of 4, by nforce4max
Check the card as some after all these years have gotten flaky so put a fan near it, if it still crashes then it is likely a software issue.
Reply 4 of 4, by ibm5155
It was driver iuse, this game doesn't work with the latest official driver, so I tried an omega driver, it worked, but, the framerates droped alot D:, even on quake2 it droped 20fps D: (making it to be lower than30fps), I tried to uninstall it and install again the older offial driver, but it didn't worked, I still get a low fps at quake2 and colin mcrae ins unplayable D:
What could I do to completly remove omega driver? ( i tried a driver cleaner but it didnt worked) because 25 to 41fps at quake 2 is a huge performance drop ;--;
