First post, by Zorbid
http://ioccc.org/2013/cable3/hint.html
The author hereby presents, for the delectation (?) of the judges, a portable PC emulator/VM written specifically for the IOCCC […]
The author hereby presents, for the delectation (?) of the judges, a portable PC emulator/VM written specifically for the IOCCC which runs DOS, Windows 3.0, Excel, MS Flight Simulator, AutoCAD, Lotus 1-2-3 …
In just 4043 bytes of C source, you get a complete mid-late 1980s-era IBM-compatible PC, consisting of:
  • Intel 8086/186 CPU
  • 1MB RAM
  • 8072A 3.5" floppy disk controller (1.44MB/720KB)
  • Fixed disk controller (supports a single hard drive up to 528MB)
  • Hercules graphics card with 720x348 2-color graphics (64KB video RAM), and CGA 80x25 16-color text mode support
  • 8253 programmable interval timer (PIT)
  • 8259 programmable interrupt controller (PIC)
  • 8042 keyboard controller with 83-key XT-style keyboard
  • MC146818 real-time clock
  • PC speaker
The emulator uses the SDL graphics library for portability, and compiles for Windows, Mac OS X, Linux and probably most other 32-bit/64-bit systems too.
Apparently, they cheat a bit regarding code size. x86 machine language is translated to a simpler instruction set, and the lookup tables are stored in the 12k BIOS. Still, it's quite a feat!
Reply 1 of 4, by SquallStrife
Slick!
Reply 2 of 4, by leileilol
My brain had a melt when reading the code... X_X
long live PCem
Reply 3 of 4, by Zorbid
I forgot this priceless snippet:
If you like living on the edge you can try building the emulator on a big endian machine, and you will get an emulation of a big endian 8086, a rather bizarre and somewhat useless beast. For everyone else, please run the emulator on a little endian machine.
Reply 4 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
We might just have some sdl startup and shutdown code that fits in 4k in dosbox. Guess the rest of the source isn't needed anymore.
