First post, by blochee
Having trouble with memory in turbo pascal v7 in DosBox 0.74 on a Windows 7 Pro 64bit.
I can get into the IDE and everything works fine.. but when I try to compile the program it says: "Error 1: Out of memory."
I've tried playing around with memsize in the config file to no avail.. I played around with loadfix, again nothing working..
When I compile it from the dos prompt using tpc.exe I get it to compile.. but the program runs slow.. real slow..
Any suggestions?
