First post, by Artex
- l33t
Hey guys,
I just picked up a Transcend 32GB 400X Compact Flash card for use in my Time Machine. It's a AMD K6 III+ 400Mhz with 32GB, and the CF card is partitioned with a single 32GB FAT32 partition where the OS is installed. The CF card is plugged directly into the IDE port using one of those CF->IDE direct-insert adapters. The motherboard is a Gigabyte GA-5AX Rev. 5.2 with the F4 BIOS.
I noticed that Windows seemed really sluggish, even after enabling DMA and changing the system role to "Network Server" through the performance tab. I fired up Sandra 99 and it reported the following. Are these CF cards just not good for Windows? I used it in DOS with zero issues..
