First post, by keropi
Hiya!
I recently got a very nice and small Hama stereo audio mixer, 2x Stereo IN and 1xOUT , perfect for soundblaster + external midi module.
I know it's a basic/simple one but it's small and tbh offers the basic function that I need. But it came without a PSU. I tried using a generic 9v one that I use for consoles and other stuff but it produces a constant triangle-wavish sound (?) (like the example here: http://en.wikipedia.org/wiki/Triangle_wave) that is audible from ~50% of master volume. Clearly too much noise from the PSU , so I tried an original Roland 9v psu from a SC-55. The parasite is still there but more quiet and more like a deep buzz now.
Ofcourse using a 9v battery solves this problem but I don't really want to mess with batteries...
So I just opened the unit , the 9v input is on the upper left side:
From what I know I don't see any input filtering (or it's a very basic one? I assume the diode is to prevent reverse current?) and I was wondering if anyone has any suggestions of how to fix this... maybe add a capacitor or two? Or some filtering component?
Any suggestion will be highly appreciated, thanks in advance! 😊
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 1 of 7, by jwt27
You'll probably need a regulated adapter. You can easily make one yourself using any 12V DC adapter, a few caps, and a 7809 IC. An example circuit can be found in the 78xx datasheet.
If you are using a regulated adapter already, the mixer might be pulling too much current from it.
Adding a large buffer cap to an unregulated 9V DC adapter might be sufficient, too.
Reply 2 of 7, by keropi
hmm
The PSU I tried is a "switching" one, variable voltages 1.2A ... it's one of the new light ones, the roland one is 10 times heavier.
I got some more questions now, from the 78xx datasheet here to which example are you referring too? the "Figure 9. Fixed-Output Regulator" one?
And about that buffer cap (that seems the easiest to test) how can I test it? does it go between vcc/gnd?
Reply 3 of 7, by jwt27
The circuit in figure 9 will do. If you need more current than 1A then go with the ciruit in figure 13 or use a different voltage regulator.
For a buffer cap you can just take any large electrolytic and connect it between +9V and ground, yes. Make sure not to connect it the wrong way around, of course 😉
A switched adapter has a lot of high-frequency harmonics though, which are difficult to filter out with an electrolytic cap. You could try adding a ceramic cap of about 10-100nf in parallel.
Reply 4 of 7, by keropi
thanks jwt27! Will test tomorrow and report 😀 both are easy.
I assume that CO 0.1μF on the datasheet is a ceramic one right? I can use a regulated 12V psu and make an internal mod with the 7809 , it seems like a good plan 😎
Reply 5 of 7, by keropi
update:
I tried today with a 2200uf + 100nf caps in the input line, sadly this made no difference using the same psu I tested before. BUT I found another switching psu (that I was considering to be of inferior quality) that does not make the parasite... So I will use that 😀
I thought of leaving the filtering inside with only one change because of room problems: the 2200uf cap became a 1500uf one
So yeah, it works fine now (for a cheap mixer that is) . Thanks again jwt27 for the help!
Reply 6 of 7, by Mau1wurf1977
I remember having a ton of issues with this.
Some of my old videos have this buzzing in the audio 😀
I tried many things, recording on a notebook on batteries, USB sound cards. In the end I got a decent Sound Card for recording (X-Fi Titanium HD), a decent mixer (it's a Phonic AM-240) and new cables. I still had issues with the video signal. Ranging from tiny jitters to constant wobbly picture. Using splitters, KVM and the VGA to S-Video adapter in various combinations minimised the issue. Best signal I got was directly of the S-Video out of a video card.
I'm curious to see how I go with my new VGA capture card. But I might soon go all digital (DVI > HDMI) on my time-machine for the purpose of capturing.
My YouTube channel
Reply 7 of 7, by keropi
yeah, it's a common problem with cheap mixers and cheap PSUs... I have another similar stereo mixer , a cheap XFADE VL-303A one, it came with it's own "double grounded" psu and is absolutely quiet. No parasites at all. But I can't really complain on the HAMA one, it was a 5eur amibay purchase and well worth it's money 🤣
Be sure to get good shielded cables Mau1wurf1977 for audio/video, cheap ones tend to pick up noise from everywhere, I had a stereo cable that picked up noise from a ps2 mouse if the cables were close 🤣
