First post, by blakespot
- Member
So, I have a corrupt volume label on the HD I am trying to setup in my 486 box. The solution for this is, apparently, to use LABEL.EXE to remove (or rename) the volume label and then FDISK can deal with the partition.
I have the three DOS 6.22 install floppies, but not working HD, so I can't "install" it anywhere. I note that on disk 2 is LABEL.EX_. I copied this to another floppy, renaming it LABEL.EXE and when I run it, the system just freezes. Are the .XX_ files compressed? If so, how can I get to a working ver of LABEL without a HD to install DOS on?
Can anyone help me in some way, here? Thanks much.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
