First post, by Guest
Could the differences be made a proactive FAQ?? It's very unclear to me why I should use DOSBox over DOSEmu or Bochs??
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Just try to use Bochs for some DOS games and you will find out the reason why to use DOSBOX. 😀
DOSEMU is Linux/Unix only program (no Windows port).
I did not check Plex86 for very long time (so I can be wrong), but it used to be even less developed than Bochs.
Mirek
