First post, by Jolaes76
I have this GW 202 baby I/O card
short overview:
http://museum.ttrk.ee/th99/i/P-R/53019.htm
in detail:
http://www.minuszerodegrees.net/manuals/GW202 … rs%20Manual.pdf
I would like to disable the floppy controller and all ports if possible, keeping the TIMER (battery supplied time and date) ONLY.
Can I do this without crippling the card, simply by blocking some of the golden fingers on the ISA edge connector ?
If yes, which ones ?
Photo of actual card attached.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 1 of 4, by sklawz
Hi
That first link demonstrates that everything other than the floppy controller
may be disabled.
From looking at the photos, there appears to be no obvious way to disable
that FDC, however, looking at the data-sheet for the device:
http://www.datasheetcatalog.com/datasheets_pd … /3/UM8397.shtml
we can see from the block diagram that if DRIVE GROUP SELECT (pin 29) on the UM8397
FDC is shorted to ground (it is currently pulled up) then the device can
be re-assigned as a secondary FDC controller with alternate I/O addresses.
This appears to be your best bet.
Bye
Reply 2 of 4, by Jolaes76
Thanks sklawz
my problem is exactly what you described - everything can be disabled via jumpers EXCEPT the the floppy controller that has the conflicting I/O range 🙁
So it seems I must get medieval on that UMC chip, after all...
Reply 3 of 4, by sklawz
hi
if you can confirm that DRIVE GROUP SELECT is simply pulled high using
that resistor pack in the bottom left (the red thing) then you can simply
just ground the pin with a wire, a very simple operation and easily
reverted later.
bye
Reply 4 of 4, by smoke86
Sorry for necroposting, but I actually tried grounding pin 29.
There is slight difference though - my FDD controller chip is HM8197 though (all UMC chips ale labelled HMxxx).
Grounding pin 29 with a wire (without lifting it from a PCB) resulted in a PC refusing to turn on - like short protection. Removing a wire made a PC turn on and POST normally.
