First post, by l_mcgregoruk
In Fifa 97, it detects my Logitech Rumblepad as TWO different joysticks, joystick 1 being the left analog stick, and joystick 2 being the right analog stick with two buttons each. I set the joysticktype to joysticktype=4axis in the .conf file, and if I set 4-button joystick to ON in Fifa 97 itself I get, the left analog stick being assigned to Player 1 AND Player 2. So I was wondering if maybe Fifa 97 is seeing the Joystick as a Gravis GrIP 4-player adapter, rather than just a normal 4-axis 4 button joystick, or 2-axis 6 button pad like joysticktype=4axis should be.
