First post, by diskers
Hi everybody 😀
So I'm asking one more time for help. I had a working configuration of FreeDOS with with grub4dos and eltotito driver as an emulated drive option at boot and it worked fine untill.....I formated the drive by mistake and the only backup I had of the FreeDOS installation was the one that was made before I configured all (in this case Eltorito and SHSUCDX) to work. The Eltorito driver is working when booting in XMS mode - the emulated drive shows the CD content and all ISOs are working fine - but when starting with Jemmex the drive is recognized , I can access it but it's empty. I must doing something wrong, because it worked before but I'm out of clue what....
Any help is wecome,
Cheers,
diskers
Reply 1 of 1, by diskers
OK it's the JEMMEX driver and all EMM386 drivers. I have to check it on a MS-DOS 6.22 or 7.1 and old EMM386 drivers....
