ALT+F12 in DOSBOX MB6
First post, by cae2544
I run Paradox 4.0 database in DosBox Megabuild 6 under Windows 7 on a Dell with an Intel i7 processor and 8M of RAM (overkill, I know.) I have tweaked MB6 with the "processor, core, and cycles" settings in the .conf file as best as possible; however, the scripts I regulary ran still crawl compared to how it ran under Windows XP (before I needed DosBox.) I hear so much about the "turbo" mode (ALT+F12) but I can't seem to access it. I know I'm doing something wrong. I have attached my .conf file for your review. Can someone help?
Reply 1 of 2, by Jorpho
MB6 is very old at this point. The latest SVN Daum build is usually recommended; it has all the features of MB6 and is much more up to date.
Also, running business-critical applications in DOSBox is generally regarded as a bad idea.
And this topic should be in the DOSBox subforum.
Reply 2 of 2, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
