First post, by PeterNLD1981
Hello,
Before i reinstalled my MacBook Pro i was able to run successfully Indiana Jones Desktop Adventures after installing and configuring Windows 3.1
But now the problem is that Windows 3.1 itself runs fine after installing sound and graphic drivers but when opening Indiana Jones Desktop Adventures it crashes DOSBox
This is the log i get:
Process: DOSBox [77998]
Path: /Applications/DOSBox.app/Contents/MacOS/DOSBox
Identifier: DOSBox
Version: 0.74-1 (0.74-1)
Code Type: X86 (Native)
Parent Process: launchd [261]
Responsible: DOSBox [77998]
User ID: 501
Date/Time: 2014-02-15 10:22:47.645 +0100
OS Version: Mac OS X 10.9.1 (13B42)
Report Version: 11
Anonymous UUID: 95C483BA-B8E3-2C63-73BA-28F5DC350C90
Sleep/Wake UUID: 6C2F7E2C-85C2-478B-BD99-55ABE8594933
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x94e26dff vsprintf_l + 49
1 libsystem_c.dylib 0x94e27098 vsprintf + 67
2 DOSBox 0x000f9b97 DBOPL::Channel* DBOPL::Channel::BlockTemplate<(DBOPL::SynthMode)1>(DBOPL::Chip*, unsigned int, int*) + 2471
3 DOSBox 0x000e74a5 VGA_UnchainedEGA_Handler::writew(unsigned int, unsigned int) + 13637
4 DOSBox 0x000200ff CPU::Change_Config(Section*) + 52959
5 DOSBox 0x00075d64 InitPageHandler::readw(unsigned int) + 336676
6 ??? 0x0de84ed6 0 + 233328342
Thread 1:
0 libsystem_kernel.dylib 0x9925b046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x9000adcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x9000ecce start_wqthread + 30
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x9925b992 kevent64 + 10
1 libdispatch.dylib 0x97d168bd _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x97d16556 _dispatch_mgr_thread + 52
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib 0x9925ab76 __semwait_signal + 10
1 libsystem_c.dylib 0x94e4f05b nanosleep$UNIX2003 + 219
2 DOSBox 0x0023ebd3 CFifo::addb(unsigned char) + 249155
3 DOSBox 0x0023ec1c CFifo::addb(unsigned char) + 249228
4 DOSBox 0x0020c1ad CFifo::addb(unsigned char) + 41757
5 DOSBox 0x00239ac1 CFifo::addb(unsigned char) + 228401
6 libsystem_pthread.dylib 0x900095fb _pthread_body + 144
7 libsystem_pthread.dylib 0x90009485 _pthread_start + 130
8 libsystem_pthread.dylib 0x9000ecf2 thread_start + 34
Thread 6:
0 libsystem_kernel.dylib 0x99255f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9925516c mach_msg + 68
2 com.apple.CoreFoundation 0x95857f69 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x95857541 __CFRunLoopRun + 1393
4 com.apple.CoreFoundation 0x95856d5a CFRunLoopRunSpecific + 394
5 com.apple.CoreFoundation 0x95856bbb CFRunLoopRunInMode + 123
6 com.apple.AppKit 0x9978df18 _NSEventThread + 283
7 libsystem_pthread.dylib 0x900095fb _pthread_body + 144
8 libsystem_pthread.dylib 0x90009485 _pthread_start + 130
9 libsystem_pthread.dylib 0x9000ecf2 thread_start + 34
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x97cd5e9a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, bool, unsigned int) + 138
3 com.apple.audio.CoreAudio 0x97cd034e HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 68
4 com.apple.audio.CoreAudio 0x97cceb27 HALC_ProxyIOContext::IOWorkLoop() + 1111
5 com.apple.audio.CoreAudio 0x97cce5ff HALC_ProxyIOContext::IOThreadEntry(void*) + 167
6 com.apple.audio.CoreAudio 0x97cd8f52 ___ZN19HALC_ProxyIOContextC2Emj_block_invoke + 20
7 com.apple.audio.CoreAudio 0x97cce4fb HALB_IOThread::Entry(void*) + 69
8 libsystem_pthread.dylib 0x900095fb _pthread_body + 144
9 libsystem_pthread.dylib 0x90009485 _pthread_start + 130
10 libsystem_pthread.dylib 0x9000ecf2 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xbfffb22c ebx: 0x000f9b67 ecx: 0x00291580 edx: 0x00000104
edi: 0xa0a5fe88 esi: 0xa0a5fe88 ebp: 0xbfffb37c esp: 0xbfffb214
ss: 0x00000023 efl: 0x00010286 eip: 0x94e26dff cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x0e75f400
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x1000 - 0x2e5f2b +DOSBox (0.74-1 - 0.74-1) <E4A05703-1010-F2C5-1ABB-659BC5B78AAD> /Applications/DOSBox.app/Contents/MacOS/DOSBox
0x202c000 - 0x206aff2 com.apple.audio.midi.CoreMIDI (1.10 - 88) <64824C07-A240-3A16-ABFF-B38FB8EAF71E> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x208e000 - 0x20a4ff8 libexpat.1.dylib (12) <B0AC9020-01C4-368F-98D6-7FFC067A1B04> /usr/lib/libexpat.1.dylib
0x22e2000 - 0x22edffa com.apple.CommerceCore (1.0 - 42) <E59717F2-6770-3DBC-8510-F7AA61E60F57> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x774c000 - 0x7771ff9 com.apple.framework.familycontrols (4.1 - 410) <A33A97EE-C735-38BA-9B49-5D78DAA3DEDA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7786000 - 0x778affd com.apple.audio.AppleHDAHALPlugIn (2.5.3 - 2.5.3fc1) <DAF7D11D-7AC8-38EA-AE89-903A9C59E1BB> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xcc43000 - 0xce43ff2 com.apple.audio.units.Components (1.9 - 1.9) <303B5E17-B3F4-3E0A-935B-E83BA0866941> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe2a000 - 0x8fe5c417 dyld (239.3) <4B280BB1-55F8-313F-86A6-8ADD644ED69E> /usr/lib/dyld
0x90008000 - 0x9000fffb libsystem_pthread.dylib (53.1.4) <8B1B7B84-1B5D-32A8-AC0D-1E689E5C8A4C> /usr/lib/system/libsystem_pthread.dylib
0x9006f000 - 0x900e5ff3 com.apple.securityfoundation (6.0 - 55122) <25149798-A37E-316F-84AB-93029EAF33D8> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x900e6000 - 0x904deff3 com.apple.CoreGraphics (1.600.0 - 599.7) <DB004990-F06F-3768-AE4C-191B3C748EFC> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90905000 - 0x90908ff9 com.apple.TCC (1.0 - 1) <A5FCF7AA-3F56-3A19-9DF1-661F1F02F79D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x90909000 - 0x909a1ff7 com.apple.Metadata (10.7.0 - 800.12.2) <5E9EA0AC-EE9E-362E-9DAC-9B7D21A53A2A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x912fd000 - 0x9130cfff libGL.dylib (9.0.83) <E76D1F2A-D98B-3464-AD0B-FC1EBBADF027> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9130d000 - 0x9130effd libunc.dylib (28) <22A126A1-DCFB-3BE5-A66B-C973F0A5D839> /usr/lib/system/libunc.dylib
0x9130f000 - 0x91311fff com.apple.securityhi (9.0 - 55005) <51765C73-80D1-33E3-9589-3E88380CE007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x91312000 - 0x91315ff7 com.apple.help (1.3.3 - 46) <AB6292FA-D3BC-3D56-B3A5-2BE630A503E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91316000 - 0x91321ffb libcommonCrypto.dylib (60049) <F8E60C43-22EE-3E0B-9546-3365056901F1> /usr/lib/system/libcommonCrypto.dylib
0x91338000 - 0x9146fff3 com.apple.desktopservices (1.8 - 1.😎 <4D853961-F911-3FE2-A7DF-3130EA1D8CEB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91470000 - 0x914b6fff libcurl.4.dylib (78) <EC84399F-5EA8-321B-B122-99730CC557C8> /usr/lib/libcurl.4.dylib
0x91694000 - 0x916e4ff7 libcorecrypto.dylib (161.1) <135FD99E-2211-3DF4-825C-C9F816107F0C> /usr/lib/system/libcorecrypto.dylib
0x916ec000 - 0x916f0fff libheimdal-asn1.dylib (323.12) <9EA2A221-301B-3B9A-BBF2-38134145B5A8> /usr/lib/libheimdal-asn1.dylib
0x916f1000 - 0x91726ffd libssl.0.9.8.dylib (50) <F3BEA2DF-DB84-37F0-B4C7-97C0A4DF19C9> /usr/lib/libssl.0.9.8.dylib
0x91727000 - 0x9198bfff com.apple.CoreData (107 - 481) <F699EC21-57D9-3AE6-A17B-C1D1092780BD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9198c000 - 0x9198effe libCVMSPluginSupport.dylib (9.0.83) <BD30BDD1-DD5B-3F31-A09B-C274EA93CD7C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x919c0000 - 0x919ffff7 com.apple.bom (12.0 - 192) <50F9D23C-9C9A-38BF-B4E2-66D93BE2A174> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x91a00000 - 0x91a01fff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x91a02000 - 0x91a06ffe libCoreVMClient.dylib (58.1) <0EB8FFD7-AFED-3A63-810E-29629831D43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x91a07000 - 0x91a0affb libutil.dylib (34) <B496031E-E763-3DEB-84D2-85C0F3DF2012> /usr/lib/libutil.dylib
0x91a0d000 - 0x91a5bff9 com.apple.HIServices (1.22 - 466) <30636237-408A-3552-90C1-1279348DF7CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91a5c000 - 0x91c08ff1 com.apple.QuartzCore (1.8 - 332.0) <07F9B77F-35A2-3D21-99FA-CD3FCE5B9C7B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x91ce3000 - 0x91cefffc libbz2.1.0.dylib (29) <3CEF1E92-BA42-3F8A-8E8D-9E1F7658E5C7> /usr/lib/libbz2.1.0.dylib
0x91cf0000 - 0x91d09fff com.apple.Kerberos (3.0 - 1) <91F17EB2-C70C-359C-B09D-96B52D2A9C9F> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91d60000 - 0x91e4bff4 com.apple.DiskImagesFramework (10.9 - 371.1) <FC13BD5A-0FB7-35D5-A8DF-0510CFA996FE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x91e4c000 - 0x91e55fff libsystem_notify.dylib (121) <623269F5-1518-3035-A916-8AF83C972154> /usr/lib/system/libsystem_notify.dylib
0x92163000 - 0x922c5ff3 com.apple.CFNetwork (673.0.3 - 673.0.3) <5E0E9AE8-073B-3F2B-B0C7-A0129DE787F6> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x922c6000 - 0x9263bff9 com.apple.HIToolbox (2.1 - 696) <43CB31D6-4C2B-30FA-A374-DB7C5728E7AD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9263c000 - 0x92668ff7 com.apple.DictionaryServices (1.2 - 208) <33873336-BECD-3F62-A315-C45F24C1818C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92669000 - 0x92671fff libcopyfile.dylib (103) <1B1484BD-08B6-3BA9-94CA-A7C24B610EB3> /usr/lib/system/libcopyfile.dylib
0x92672000 - 0x92709ff7 com.apple.ink.framework (10.9 - 207) <EF00BCCB-B270-3F3D-9424-EF5F4BC23E25> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9270a000 - 0x92740fff com.apple.IconServices (25 - 25.17) <A4B5242B-765E-3D58-B066-BBEDB5947AAD> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x9274f000 - 0x92757fff liblaunch.dylib (842.1.4) <3798500D-4436-3AEB-B273-7F2428C33A4A> /usr/lib/system/liblaunch.dylib
0x92866000 - 0x9286bff3 libsystem_platform.dylib (24.1.4) <875321B9-34EF-3FCC-880C-633FA05223F5> /usr/lib/system/libsystem_platform.dylib
0x9286c000 - 0x92880ff9 com.apple.MultitouchSupport.framework (245.13 - 245.13) <6860A0D0-3654-3B02-B2E9-C4D2637167B8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x92881000 - 0x928b1ff7 com.apple.CoreServicesInternal (184.8 - 184.😎 <88528205-9452-3EEC-BB27-DAAA7EC81E04> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x928b4000 - 0x928ecff7 com.apple.MediaKit (15 - 709) <82E0F8C0-313C-379C-9994-4D21587D0C0C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x92bbf000 - 0x92beefff com.apple.framework.SystemAdministration (1.0 - 1.0) <05E81260-7DC7-3546-B45D-15B3E5DF056D> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x92ea4000 - 0x92ec8fff libxpc.dylib (300.1.17) <252BC88F-A5CA-3E67-AEDB-3D7B9F4537E2> /usr/lib/system/libxpc.dylib
0x931db000 - 0x9322afff com.apple.opencl (2.3.57 - 2.3.57) <93385E1C-00D9-31BE-9652-7F3C09484B3E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9322b000 - 0x9322dffb libRadiance.dylib (1038) <F0D3F13B-5628-3DF9-8B86-A4D914567B25> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9322e000 - 0x93234ffb libunwind.dylib (35.3) <099D1A6F-A1F0-3D05-BF1C-0A7BB32D39C2> /usr/lib/system/libunwind.dylib
0x93236000 - 0x93322ff7 libxml2.2.dylib (26) <32040145-6FD6-3AD2-B98B-39F73BF9AC47> /usr/lib/libxml2.2.dylib
0x93323000 - 0x93327ffa libGIF.dylib (1038) <5CEB4EDF-B0B6-33A6-BDDE-8C0D3226FA72> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x93328000 - 0x93389ff7 com.apple.Symbolication (1.4 - 129) <E5948C08-6ADF-3D86-9134-6AE49CF1DA0F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x9338a000 - 0x9338bffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9338c000 - 0x9367eff8 com.apple.CoreImage (9.0.54) <D7BC3E53-EF5B-3A14-8808-8D45EE505B48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9367f000 - 0x9368cfff com.apple.Librarian (1.2 - 1) <F85681E3-3398-327B-829B-1D8078C38C22> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x9368d000 - 0x936beffd com.apple.GSS (4.0 - 2.0) <6BA01155-4DAD-30EE-B480-D224650EA010> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x940ef000 - 0x941d2ff7 libcrypto.0.9.8.dylib (50) <B367D3A3-FC1F-326C-92EC-CAD81666524D> /usr/lib/libcrypto.0.9.8.dylib
0x941d3000 - 0x941efff9 com.apple.Ubiquity (1.3 - 289) <1CEDC83D-7282-3B4D-8CF7-4FE045012391> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x941f0000 - 0x9451bff6 com.apple.Foundation (6.9 - 1056) <C8AE9C03-3460-354A-A8B6-EF4955BE600D> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9451c000 - 0x94524ff7 libCGCMS.A.dylib (599.7) <A7404924-9A2B-3324-A934-BD08953E7098> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x94841000 - 0x948aafff com.apple.datadetectorscore (5.0 - 354.0) <A5559FE6-7A00-383D-8665-C0D622409D85> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x948ab000 - 0x94cdfff7 com.apple.vision.FaceCore (3.0.0 - 3.0.0) <5B12F3E9-84F6-3183-B85D-FD19EF800ADB> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x94cf7000 - 0x94dd2ff7 com.apple.LaunchServices (572.23 - 572.23) <7E52FB5C-9ECF-3CB9-BF18-6652B8D8CDE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94dd3000 - 0x94e65ffe libsystem_c.dylib (997.1.1) <D06FD754-8CE3-3EB7-BE05-2EF939BBE05F> /usr/lib/system/libsystem_c.dylib
0x94e66000 - 0x94e66fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <DDAC0B59-F886-3AB1-98E8-C71FFF161CD4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94e67000 - 0x94e67fff libkeymgr.dylib (28) <1B097DEA-011E-3B1C-86D5-6C7FAD5C765A> /usr/lib/system/libkeymgr.dylib
0x94e71000 - 0x94f41fef libvDSP.dylib (423.32) <E2FA7230-A001-3F6B-9ACF-6998C51AD7DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94f48000 - 0x94f51fff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <CF8E5706-F744-3139-8A51-D52BF055D19F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x94f85000 - 0x95052ff7 com.apple.backup.framework (1.5.1 - 1.5.1) <91998CDF-3547-3183-A962-D9E981C14891> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x95053000 - 0x95053fff com.apple.Carbon (154 - 157) <C49AD4A1-8DE3-357D-AEF3-D6CD39EA91EF> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x95056000 - 0x950d6ff7 com.apple.CoreServices.OSServices (600.4 - 600.4) <1227DF22-E2DA-3764-A1CA-10CC0CEBE377> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x950d7000 - 0x95114ff7 libauto.dylib (185.5) <CD008E66-4A0C-35F5-8D72-80D76A716A03> /usr/lib/libauto.dylib
0x95115000 - 0x9512dfff com.apple.CFOpenDirectory (10.9 - 173.1.1) <630A5CCF-8FC3-379D-B0BD-41DCE1F0B624> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9512e000 - 0x9512effd com.apple.audio.units.AudioUnit (1.9 - 1.9) <8A37963C-DF6F-3DFF-94E9-407DC5DFEDA9> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9512f000 - 0x95141fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x95469000 - 0x954c2ffa libTIFF.dylib (1038) <691DAAFD-D72B-3BE9-AE5C-84AF86BE66CD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x956da000 - 0x9579dff1 com.apple.CoreText (352.0 - 367.15) <746AD442-F7B4-3273-A36D-C7103D26F727> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x9579e000 - 0x957e0fff libGLU.dylib (9.0.83) <0D9BFE5A-435E-3C66-AF96-D3567B8FC87B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x957e1000 - 0x959e3ff7 com.apple.CoreFoundation (6.9 - 855.11) <50F70E07-043A-3A2F-87EF-A36BA6C5C9D9> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x959e4000 - 0x959e5fff libSystem.B.dylib (1197.1.1) <C58F0CC9-C1FD-3024-9358-D3359A6BBCAD> /usr/lib/libSystem.B.dylib
0x959f1000 - 0x95a22ffa libsystem_m.dylib (3047.16) <28E614E8-7802-3E84-960A-AD4721EF10F7> /usr/lib/system/libsystem_m.dylib
0x95a2d000 - 0x95b3fffc libsqlite3.dylib (158) <B3DB0FED-FE4C-314D-8329-CF7708C8AAF4> /usr/lib/libsqlite3.dylib
0x95b6a000 - 0x95d124af libobjc.A.dylib (551.1) <31CBE178-E972-30D1-ADC6-4B8345CAE326> /usr/lib/libobjc.A.dylib
0x95d13000 - 0x95d50ffb libGLImage.dylib (9.0.83) <FA15FEB5-54E4-313B-8E78-A2D2E6C88FE1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95d51000 - 0x95e4ffff libJP2.dylib (1038) <EE0B9985-625D-39E6-B425-03FB75BA2594> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x96038000 - 0x9603dff7 com.apple.print.framework.Print (9.0 - 260) <A6C465F6-C5D1-353A-9F33-19B9CEDBBC2A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9603e000 - 0x96045ff2 com.apple.NetFS (6.0 - 4.0) <915AA303-C02B-3B0C-8208-D8AAA4350DB4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x96046000 - 0x96054fff libxar.1.dylib (202) <B73748D4-F830-3C71-98B3-7A3ABF5136FD> /usr/lib/libxar.1.dylib
0x96070000 - 0x96074ff7 libmacho.dylib (845) <D8E93E59-1F80-3413-B9CF-78B848F6E873> /usr/lib/system/libmacho.dylib
0x96075000 - 0x962e2ff6 com.apple.security (7.0 - 55471) <5FCF76B2-92C6-3404-87D3-91B3F6E203AA> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x962e3000 - 0x96356fff com.apple.SearchKit (1.4.0 - 1.4.0) <6F607AB6-7553-37BA-BEC5-98FD7C27FAD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x963ad000 - 0x963f9ff7 libcups.2.dylib (372) <9A2BE8DC-37E4-3019-B665-1036FE7868EA> /usr/lib/libcups.2.dylib
0x963fa000 - 0x96436ff4 com.apple.RemoteViewServices (2.0 - 94) <BEEE6ADF-7DA3-3D68-BCB0-9863BE1A1F46> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x96464000 - 0x9652bff7 com.apple.DiscRecording (8.0 - 8000.4.6) <84A7EC09-3BBD-3E04-A88C-6D3B724448FF> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x9652c000 - 0x966f2ffb libicucore.A.dylib (511.27) <653147E9-7326-337A-99E1-B42E4D801E53> /usr/lib/libicucore.A.dylib
0x966f3000 - 0x966fcfff com.apple.DiskArbitration (2.6 - 2.6) <6379523D-3196-370C-AE4A-8EA586E36909> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x96701000 - 0x96701fff com.apple.ApplicationServices (48 - 48) <7967F6FA-2984-3CC3-AD9A-7B9AEC562A2A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96702000 - 0x96703fff libsystem_blocks.dylib (63) <2AC67D5E-ECD4-3644-A53C-9684F9B7AA33> /usr/lib/system/libsystem_blocks.dylib
0x96704000 - 0x96716fff libsystem_asl.dylib (217.1.4) <51EB17C9-9F5B-39F3-B6CD-8EF238B05B89> /usr/lib/system/libsystem_asl.dylib
0x96717000 - 0x9678cff1 com.apple.ApplicationServices.ATS (360 - 363.1) <5C9BC698-0CC1-3F6A-9F9D-BCC3A9C3D6DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9678d000 - 0x967a0fff com.apple.ImageCapture (9.0 - 9.0) <63D5C96F-1893-3F35-ADFB-EE451AFD87E6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x967a1000 - 0x967afff3 com.apple.opengl (9.0.83 - 9.0.83) <16CFFD50-217E-3E18-88AF-7F2AD980628B> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x96865000 - 0x968bbff6 com.apple.ScalableUserInterface (1.0 - 1) <2C81641B-FA30-32FF-8B3E-3CB9BF53B2D9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x968d4000 - 0x968dffff com.apple.CrashReporterSupport (10.9 - 538) <7A5FF845-433C-33E3-99B5-F6AA5B825734> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x968e0000 - 0x968e3ffe com.apple.LoginUICore (3.0 - 3.0) <6FE961A4-3C17-3004-B50B-FD78FDC28350> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x96ae7000 - 0x96eacff6 libLAPACK.dylib (1094.5) <E6286E68-3501-31AC-813E-75B3B3968011> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x96ead000 - 0x96eb0ffa libCGXType.A.dylib (599.7) <2738FF52-4B47-31AD-B7E5-412F6AFACC2A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x96ee4000 - 0x96eefff6 com.apple.NetAuth (5.0 - 5.0) <3B2E9615-EE12-38FC-BDCF-09529FF9464B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x96ef0000 - 0x96efcff7 com.apple.OpenDirectory (10.9 - 173.1.1) <2AA24814-2DC6-3E28-B71B-186B686F0F19> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x96f08000 - 0x96fa7ff7 libCoreStorage.dylib (380) <55467C87-E1A3-3057-B428-9BCEFD39E36D> /usr/lib/libCoreStorage.dylib
0x96fa8000 - 0x96fd2fff libxslt.1.dylib (13) <249D54AB-1D82-38FE-ABEC-0D575450C73B> /usr/lib/libxslt.1.dylib
0x96fd3000 - 0x96fd3fff com.apple.CoreServices (59 - 59) <06747539-5035-3307-8645-9BC4E7F89023> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97361000 - 0x97365fff com.apple.CommonPanels (1.2.6 - 96) <E7CA63C6-CEE9-3F0A-93A7-C12C653FFB80> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9736f000 - 0x9737fff7 libsasl2.2.dylib (170) <CA1C07F6-8E17-315E-AE49-AB696DDE6707> /usr/lib/libsasl2.2.dylib
0x97423000 - 0x97469ff7 libFontRegistry.dylib (127) <A0930DB2-A6C6-3C6E-B4A2-119E0D76FD7D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9746a000 - 0x97474fff com.apple.bsd.ServiceManagement (2.0 - 2.0) <B84F3916-236A-347B-9C1F-3DE571496737> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x97475000 - 0x97477fff libsystem_configuration.dylib (596.12) <1C31C3F6-568D-3854-AE03-A5DA2F39297E> /usr/lib/system/libsystem_configuration.dylib
0x97478000 - 0x974e1fff com.apple.SystemConfiguration (1.13 - 1.13) <542075CD-9085-3F30-B84B-DD0277D6A40E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9754d000 - 0x97659fff com.apple.ImageIO.framework (3.3.0 - 1038) <0B4A6607-9FBC-3A6C-984A-0542DE8385FB> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x97709000 - 0x9770dffc com.apple.IOSurface (91 - 91) <DECEEB72-3C7E-3C21-9237-E5AD293F8B09> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9770e000 - 0x97717fff com.apple.audio.SoundManager (4.1 - 4.1) <68B7CEB7-AF09-3E24-8548-6ABF065B5186> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x97718000 - 0x97735ffb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x97bde000 - 0x97be9fff libcsfde.dylib (380) <C9E61AFB-1A9D-324B-9827-06B182CDD7B0> /usr/lib/libcsfde.dylib
0x97bea000 - 0x97c11fff com.apple.CoreVideo (1.8 - 117.2) <A53FDD90-F200-3F7C-8A8E-5DE36D3DFBB0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97c12000 - 0x97c16ffa libcache.dylib (62) <9730D7F2-D226-3F30-8D26-BF598CB781F6> /usr/lib/system/libcache.dylib
0x97c17000 - 0x97c45ff3 com.apple.DebugSymbols (106 - 106) <FC70F4C9-B2A6-352F-9563-6C085E9DDDB8> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x97c46000 - 0x97cbbffb com.apple.framework.IOKit (2.0.1 - 907.1.13) <86D72735-9DFB-35C8-83F7-CE0DCF17D354> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x97cbc000 - 0x97cbcffd libOpenScriptingUtil.dylib (157) <4D06E8ED-D312-34EA-A448-DFF45ADC3CE5> /usr/lib/libOpenScriptingUtil.dylib
0x97cbd000 - 0x97d12ff7 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <0F1C111F-1E64-33BB-A69F-14643B3037D5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97d13000 - 0x97d2bffd libdispatch.dylib (339.1.9) <6249BAE5-044F-3A7A-9CCC-03FF7E6B405B> /usr/lib/system/libdispatch.dylib
0x97d8f000 - 0x97daaff6 libPng.dylib (1038) <F39168D4-ABEB-3C2D-A763-B9D3E1EF43BC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x97dab000 - 0x97f1dffb com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <E5FFD35D-18CF-333C-BECE-39F8E47BE707> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x97f1e000 - 0x97f26fff libsystem_dnssd.dylib (522.1.11) <1C015806-B971-34F9-B162-3DF7897351D0> /usr/lib/system/libsystem_dnssd.dylib
0x97f27000 - 0x97fb8fff com.apple.ColorSync (4.9.0 - 4.9.0) <8366AE10-0396-3100-B87A-A176E8ECE7B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98242000 - 0x98248ff7 com.apple.AOSNotification (1.7.0 - 760.3) <63F7E7F8-6FA3-38D3-9907-CDF360CA9354> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x9827a000 - 0x9827bfff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x982bc000 - 0x98327ff9 com.apple.Heimdal (4.0 - 2.0) <E3091095-A893-3089-8DA1-8705B3BE5BF9> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9838f000 - 0x98392fff libdyld.dylib (239.3) <729B32AC-EEE2-3739-8CE3-F90838D51906> /usr/lib/system/libdyld.dylib
0x98393000 - 0x98483ffb libiconv.2.dylib (41) <848FEBA7-2E3E-3ECB-BD59-007F32468787> /usr/lib/libiconv.2.dylib
0x987cb000 - 0x987e5ff7 com.apple.GenerationalStorage (2.0 - 160.2) <8755F7F1-2402-387C-A32A-2270E7D680C8> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9904b000 - 0x99066ff5 com.apple.openscripting (1.4 - 157) <5C161A52-8D2F-3D56-A988-05727BED7A59> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x99067000 - 0x99069fff libquarantine.dylib (71) <EE3B510E-1AEC-3171-8A1A-D6A5A42CF35C> /usr/lib/system/libquarantine.dylib
0x9906a000 - 0x99095ff7 libsystem_network.dylib (241.3) <71EBA489-386D-3608-ADE6-CB50EBD1AB1B> /usr/lib/system/libsystem_network.dylib
0x99096000 - 0x99132fff com.apple.QD (3.50 - 298) <F73FD4D4-17A4-37D6-AC06-7CA5A8BA1212> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x99189000 - 0x991e7ffd com.apple.AE (665.5 - 665.5) <54F2F247-160C-3A22-A6E3-5D49655A67AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x991e8000 - 0x9923bfff com.apple.htmlrendering (77 - 1.1.4) <408FA30F-4FE9-3162-9FFD-677E8569C1EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x99243000 - 0x99260ff4 libsystem_kernel.dylib (2422.1.72) <C5641F6C-E271-380A-A656-AE4C04345602> /usr/lib/system/libsystem_kernel.dylib
0x99261000 - 0x9928cff5 com.apple.ChunkingLibrary (2.0 - 155.1) <50BBBBF8-F30B-39EA-A512-11A47F429F2C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x992e2000 - 0x99306fff libJPEG.dylib (1038) <212B0986-9227-397C-9493-BCB190EC020E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x99307000 - 0x99310ffa com.apple.CommonAuth (4.0 - 2.0) <6CB82D57-3C55-39E5-9036-8047DF3E6F57> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x99311000 - 0x99319ffe libGFXShared.dylib (9.0.83) <35644AAA-B1E7-367C-90C0-378024F8A46A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9931a000 - 0x99332ff7 libsystem_malloc.dylib (23.1.10) <69F485C9-B3E7-3E36-A06C-D7DFD29D22E1> /usr/lib/system/libsystem_malloc.dylib
0x99333000 - 0x99343ff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <71DE7754-0A47-3F35-B1BF-B1FE7E1311E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x99344000 - 0x99395ff1 libstdc++.6.dylib (60) <354F284B-2343-3810-9CA2-E28038824F6E> /usr/lib/libstdc++.6.dylib
0x993fe000 - 0x9940bff7 com.apple.AppleFSCompression (56 - 1.0) <0C44B3E4-C4A7-3A65-9C1A-334CA3E35BDB> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x9940c000 - 0x99562ff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x99563000 - 0x9956dff7 com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <16E20DCD-89F4-3C8E-9DBA-EED359807038> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x995bd000 - 0x9a1d8ff3 com.apple.AppKit (6.9 - 1265) <AE258D94-0272-394F-BBB7-9B5C165A4A78> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9a1d9000 - 0x9a1deff6 libcompiler_rt.dylib (35) <9924DF2E-D80B-3A21-920D-544A4597203F> /usr/lib/system/libcompiler_rt.dylib
0x9a1df000 - 0x9a207fff libsystem_info.dylib (449.1.3) <BB68E8CC-422F-3121-8C86-D0F766FB696D> /usr/lib/system/libsystem_info.dylib
0x9a234000 - 0x9a242ff7 com.apple.Sharing (132.2 - 132.2) <87DBFC7A-9689-3B8E-AD16-5A9DFF9DE625> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x9a243000 - 0x9a2efffb libvMisc.dylib (423.32) <43873EFF-FB43-3301-BEE8-F2C3A046D7A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9a2fb000 - 0x9a350fff libc++.1.dylib (120) <10C0A136-64F9-3CC2-9420-013247032120> /usr/lib/libc++.1.dylib
0x9a351000 - 0x9a35bff7 com.apple.DirectoryService.Framework (10.9 - 173.1.1) <D6735614-EF4B-389F-BF99-7D8416A504BA> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9a35c000 - 0x9a450fff libFontParser.dylib (111.1) <D8F9B2A4-41A6-3407-8D80-13A841F97BE5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9a451000 - 0x9a451fff com.apple.Cocoa (6.8 - 20) <407DC9E6-BBCE-3D34-9BBB-00C90584FFDF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9a452000 - 0x9a4dbfff com.apple.CoreSymbolication (3.0 - 141) <178DDF5C-B6DA-39BD-84F5-FD3FA7E93BF8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9a4e1000 - 0x9a4efff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x9b38c000 - 0x9b390ffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x9b391000 - 0x9b391fff libodfde.dylib (20) <98FC02AE-C596-3ED5-80D1-C502FF6115ED> /usr/lib/libodfde.dylib
0x9b392000 - 0x9b3dafff com.apple.PerformanceAnalysis (1.47 - 47) <16935C0F-7F9F-316E-9D46-11973DE0904A> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9b3db000 - 0x9b6dcff7 com.apple.CoreServices.CarbonCore (1077.14 - 1077.14) <42E10BD1-995B-3FB4-8A6D-5FD071FB8BD1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9b6dd000 - 0x9b6ddfff com.apple.Accelerate (1.9 - Accelerate 1.9) <C85070A7-D942-3CFA-981F-5864480788C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9b6de000 - 0x9b6dfffa libsystem_sandbox.dylib (278.10) <F3C9C427-AF9F-3CE0-95FF-DC9ACA0B5760> /usr/lib/system/libsystem_sandbox.dylib
0x9b6e0000 - 0x9b6fcfff libCRFSuite.dylib (34) <FFF76EBA-DF35-3A5F-857F-3F4B1C9F4C77> /usr/lib/libCRFSuite.dylib
0x9b6fd000 - 0x9b6ffff2 com.apple.EFILogin (2.0 - 2) <BC558029-74C0-3A69-B376-8F4CBF8C338F> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9b700000 - 0x9b728ff7 libRIP.A.dylib (599.7) <461297C0-DDA9-3613-8F27-D7F1AC57208F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9b729000 - 0x9b74cff7 libc++abi.dylib (48) <5367BE5A-D475-3FB4-972D-E1DC999A709A> /usr/lib/libc++abi.dylib
0x9b8b7000 - 0x9b913ffa com.apple.print.framework.PrintCore (9.0 - 428) <3E248391-2669-328B-B84F-8763FE8E92BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9b914000 - 0x9b9faff7 com.apple.coreui (2.1 - 231) <1C1AE894-C5C2-3F1C-BF29-B152ECD9BD88> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9b9fb000 - 0x9bce5fd2 com.apple.vImage (7.0 - 7.0) <256972F0-3DBC-3CE1-9EE8-B48243868729> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9bce6000 - 0x9bd24ff7 com.apple.NavigationServices (3.8 - 215) <A093AAF0-248E-313E-BA82-01F69E269895> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9bd25000 - 0x9bd26fff libremovefile.dylib (33) <ED35EA79-EB06-3B84-A6D4-B1A9D6B8648D> /usr/lib/system/libremovefile.dylib
0x9bd27000 - 0x9bd5ffff com.apple.LDAPFramework (2.4.28 - 194.5) <0C42A932-15E8-3CD1-AC35-1DF7D41B25A2> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x9c2ce000 - 0x9c2daffe libkxld.dylib (2422.1.72) <F9B35FA5-C936-3286-A055-2B0780A674AC> /usr/lib/system/libkxld.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 443841
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=141.3M resident=22.9M(16%) swapped_out_or_unallocated=118.3M(84%)
Writable regions: Total=193.7M written=74.5M(38%) resident=85.1M(44%) swapped_out=15.5M(8%) unallocated=108.7M(56%)
REGION TYPE VIRTUAL
CG backing stores 3296K
CG image 12K
CG raster data 24K
CG shared images 212K
CoreServices 2112K
Kernel Alloc Once 4K
MALLOC 129.6M
MALLOC (admin) 48K
MALLOC_LARGE (reserved) 4K reserved VM address space (unallocated)
Memory Tag 242 12K
Memory Tag 249 156K
Stack 69.1M
VM_ALLOCATE 16.7M
__DATA 42.9M
__IMAGE 528K
__LINKEDIT 44.0M
__OBJC 1840K
__PAGEZERO 4K
__TEXT 97.2M
__UNICODE 544K
mapped file 159.7M
shared memory 4K
TOTAL 567.9M
TOTAL, minus reserved VM space 567.9M
Model: MacBookPro9,1, BootROM MBP91.00D3.B08, 4 processors, Intel Core i7, 2.3 GHz, 4 GB, SMC 2.1f175
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 1024 MB
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333235533643465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.0f6 12982, 3 services, 15 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS547550A9E384, 500,11 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: IR Receiver
USB Device: Apple Internal Keyboard / Trackpad
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
