Midi under Linux
First post, by XulChris
anyone know how to set up midi under linux? Im using OSS for sound.
TIA,
Chris
Reply 1 of 1, by jurgen
With my Sound Card (SB audigy), I had no sequencer (midi) support using the OSS driver.If you own this card (or a SB Live! or similar) I'm afraid you'll have to use the ALSA driver (don't know what Linux distribution you use, but on Suse , you can easily select this in the Yast configuration utility). For Audigy and related cards, for which the midi patches have to be loaded from disk, there are a bit more steps to follow, but this gets off - topic.
hope this helps,
greetings,
J.
