First post, by senrew
I've acquired a beast of an AT tower machine with a 486 motherboard. I pulled it out and tried to power it up to check it out but the thing won't post. Here are the details.
What appears to be a ZEOS Gosling motherboard. The thing is loaded up with built in stuff. VLB, onboard adaptec SCSI, IDE/Floppy controller, coin cell battery.
It had some kind of ISA NIC that's irrelevant, and a VLB Diamond Speedstar Pro. I stuck in some EDO ram simms and powered it on. The PSU spins up, the floppy and CD drives do their power up cycle, but I get no image on my monitor and no POST beeps.
I've never had the chance to really mess around with a 486 board before this (except for that one that was DOA that I picked up from a friend). Any help in diagnosing this thing or finding jumper configs or even a manual would be appreciated.
I've tried googling but the only things that come up for "ZEOS Gosling" are a few newsgroup posts with links that have been dead for years.
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
Reply 1 of 5, by Tetrium
Chances are your 486 board will only post with FPM instead of EDO. Do you have any FPM memory laying around?
Remember that you'll need only 1 stick, 486's don't need pairs 😀
My retro rigs (old topic)
Report spammers here!
Reply 2 of 5, by senrew
Well, that did it. Found a little baggie of ram that said "ZEOS FPM 4MB Modules" on it. The thing booted right up.
I dug through the boxes of parts that came with all the machines I got in this haul and found an old WD Caviar 1gig drive and figured that'll do. Turned the machine on, checked the BIOS to make sure the hard drive parameters were set correctly...and they happened to match the particular drive I randomly grabbed.
I rebooted, DOS started up on the drive, loaded the ASPI CD drivers...and then the thing booted into Netware 4.0. I guess my friend's dad used this thing as a server at some point.
Anyway, as the machine currently sits:
ZEOS Gosling
486 (I think it's a DX 33. The BIOS reports a fpu and 33mhz speed)?
8MB FPM ram
WD Caviar 1GIG
Diamond Speedstar Pro VL 1MB
3.5/5.25" floppy drives
Toshiba something or other SCSI CD drive
Thinking of dropping in either one of the SB16s I have or the CT 4380 AWE64 as a sound card and be done with it parts wise.
I still need to find some kind of manual or jumper settings or something for this thing. Anyone know where I could find those?
Reply 3 of 5, by Tetrium
senrew wrote:
Well, that did it. Found a little baggie of ram that said "ZEOS FPM 4MB Modules" on it. The thing booted right up. […]
ZEOS Gosling
8MB FPM ram
WD Caviar 1GIG
Cheers! That's one problem out of the way! 😁
For jumper setting, my preferred way is to find it's model number and manufacturer.
A really good source is "Total Hardware 99" (or just th99 in short), you can find it by using google.
If you can take a clear picture of the board and write down all printed words/numbers on the board and upload them, perhaps I could help you find the correct entry in th99 😀
Reply 4 of 5, by senrew
TH99 doesn't have the Gosling on there. It has a few other Zeos boards but not that one, so that's a loss 🙁
Reply 5 of 5, by senrew
I recently found this:
http://www.mpcdrivers.com/file_lib/zeosbbs/zeosbbs.html
Seems to be a partial archive of the Zeos BBS files. I'll see if I can run through some of the files to get an exact identification of my motherboard when I get home.
Figure the link might be helpful for anyone else with issues with Zeos boards.
