Com ports
First post, by Unknown
I Just want to know if the comms port work with dos box. I'm trying to get a software package working which using the comm port to get to a remote device... Is the possible? does DOSBox run comm ports? do I have to set it up?
Reply 1 of 2, by iampiti
No, they don't work and AFAIK there are no plans to implement it.
Iampiti
Reply 2 of 2, by Snover
They are emulated, not virtualized. If you want to use your serial ports in DOSBox you'll need to write that passthru functionality yourself.
Yes, it’s my fault.
