First post, by pinnerite
I have a large Clipper collellmpiled MS-DOS program that runs under Windows and also runs under Dosbox. The problem is that I need it to 'talk' to a Windows-resident utility called PageScript that enables it to print to Windows computers (and indirectly to those of a Linux host). I cannot see how to overcome this from Dropbox.
Trying to run both programs under wine failed, leaving the suggestion to deploy dropbox!
Reply 2 of 2, by Jorpho
collellmpiled?
DOSBox is not meant for running applications and there is generally no way for an application running in DOSBox to communicate with a Windows program. Generally, the best you can do is set something up in Windows that will respond when a file or directory is changed (i.e. by a program running in DOSBox).
Alternatively, you can rewrite the DOSBox source code to make it do what you want if you're sufficiently desperate.
