probably dumb question
First post, by Guest
if i am trying to install this on a linux system, do i just type ./configurator and then make depend, and then make, and then make install? any help would be great
Reply 1 of 1, by Magamo
You run ./configure (And add options if you feel so inclined)
Then 'make' (Optionally, you can use custom CXXFLAGS here) followed by
'make install' when the build process completes.
