First post, by Mau1wurf1977
- l33t++
Hi all!
I'm having issues getting Voodoo cards going on Pentium 4 systems.
I tried 2 boards so far. One from Asrock: http://www.asrock.com/mb/intel/p4i65g/ and one from Gigabyte: http://www.gigabyte.com/products/product-page … spx?pid=1647#ov
The issue is exactly the same.
I did the following:
- Install W98SE
- Install chipset drivers
- Install Matrox drivers
- Install Monster 3D drivers
- Install DirectX 6.1
After the Monster drivers are loaded and I right click onto the desktop > properties to access the Voodoo driver, nothing happens. When I shut down the computer I get a message "DDE Window Server not responding:. It's as if the voodoo driver or something is stuck in a loop.
Games crash with the "Mutual exclusion prohibits this"
Dxdiag hangs when testing the display capabilities (Matrox tests fine).
I'm missing something obvious. Some patch or other incompatibility that needs ironing out.
There are no issues in device manager. All devices working well.
If, after a fresh boot, I run straight away Unreal, the game works. But each time I try to access display properties the same issues appear again.
Hopefully someone out there has experience with this and can help me out 😀
