First post, by Alice
Hi everyone,
At this point I am terribly exhausted and rather desperate after trying for days to install Shivers2 (Harvest of Souls) under my Win2000Pro (SP4) (CPU: Intel Celeron 1GHz). This is a Sierra game that is supposed to run under Win3.1 or Win95. (I know this is not a 'very' old game so you might think this is not a subject for 'hardcore' Vogons, but anyone who has any idea and some time, please give me a reply, it will be greatly appreciated!!)
The whole thing is more than a mystery and I'm thinking about taking up the "Sherlock" middle name already. I have the original copy of the game, which I tried to install from the CD. The installation fails with a "General Protection Fault". I tried to install it with apcomp.exe, choosing Win95, and also Win98, but all I get is error messages: it just wouldn't run. After a day or two I realized that during the attempt of normal setup (not with apcomp), the program hideously copies the setup files and some dll's to my C:\winnt\temp and that is where it seems to run from. That is, if after each and every unsuccessful attempt I manually kill "setup" and the mystical "wowexec" tasks in task manager. Without this, all I get is GPF, or simply nothing.
New chapter. I kill wowexec and start setup from c:\winnt\temp. Setup runs, but tests my machine and comes up with this error message: "You have 176781 KB free memory (8832 KB physical). You need a total of at least 10500 KB free (12000 KB physical) to run Harvest of Souls. To free up some memory, close down other Windows applications and try again." So I do not meet the "physical memory" requirement. Now. I have 128 MB ram. I restart, and kill my firewall, antivirus, and other things, run disk cleanup, defragment all my drives about 3 time each, and start setup again. Same problem. I download RamIdlePro, a ram defrag and management tool, install it, and require it to free up at least 64 MB RAM. It does so. I run setup: same problem, same amount of physical mem: 8832 KB EXACTLY.
Now I tell setup to never mind that the prog won't run, install it. It does so. The game starts to run, but at the intro video the sound gets stuck in a loop and all i can do is skip it, even though the movie goes on. Since the game is full of videos the sounds of which are crucial from the point of view of the plot, this practically makes it impossible to play. Since I have the damn game installed already I decide to delete my c:\winnt\temp files. The game from this point doesn't even start, but executes errors or encounters problems and shuts down. So I have to go though the same process for the 100th time again.
The big mystery is why do I have (acc. to the setup) 8832 KB free physical memory?? I can do whatever I can, it just wouldn't change. Or is "physical memory" not RAM? What the heck am I supposed to do to avoid going mad and burn my Harvest CDs under ritual circumstances?
Reply 1 of 9, by Snover
Don't let the game test your system and you will be allowed to install. 😀
Yes, it’s my fault.
Reply 2 of 9, by Alice
Thanks for the reply, Snover.
As I have said, finally I did what you suggested, and installed the software without letting it test the system. However, as I described above, the sound isn't working properly during the game, gets stuck in a loop already at the beginning, like an old gramophone record. I suspected that it's due to the "physical memory" requirement fail, that's why I asked about the memory thing.
Reply 3 of 9, by Snover
I just tested it myself and had no problems whatsoever with the sound.
Yes, it’s my fault.
Reply 4 of 9, by Alice
I tried your suggestion and with apcompat, set to win98 (and only with that setting), out of the two executables in my install folder, the one named "shivers2" (but not the other) seems to be working correctly (haven't tested it thoroughly yet). It's not absolutely perfect, there are some minor skips in sound (and sometimes a little in video), but it IS working at last!!
***Thank you for the great help and testing, Snover, Vogons are the *best* on the net!!!***
Reply 5 of 9, by Snover
RSHIVERS is the actual game.
Yes, it’s my fault.
Reply 6 of 9, by Alice
Oh, is it? What is shivers2.exe, then? 😦
The problem is that starting rshivers without APCOMPAT gives me the mentioned problems, while starting it with APCOMPAT it gives me this error message:
MSVCRT.DLL for Win32
Error: MSVCRT.DLL is not compatible with Win32s.
Consequently, it seems that I have to use shivers2.exe with APCOMPAT (Win98), though I'll get a stroke, I'm sure, if it turns out in the middle of the game that I can't play it any further...
Reply 7 of 9, by Snover
SHIVERS2.EXE is the "Please wait Shivers is loading" screen (because the game takes like 40 seconds to load) that calls RSHIVERS.EXE.
Yes, it’s my fault.
Reply 8 of 9, by Alice
Hmm... That's even more mysterious then...because as I said, one runs and the other does not...
Anyway, I hope it will work properly all through the game...
Reply 9 of 9, by Snover
No, it runs, it just takes a LONG time to load.
Yes, it’s my fault.
