First post, by tordeck
How do prevent it from doing this because the graphics look blocky and the text in games sometimes don't display properly. I tried setting the scaler to none in dosbox.conf file but nothing happens to problem is still there.
Canadacow please help.
Reply 1 of 11, by teamster1975
I'm afraid that I can't help you, but you'll get a quicker response from someone in the know if you post this in the main Dosbox forums; this is really only for support on the MT-32 emulation.
Reply 2 of 11, by tordeck
I'm sorry if I had posted on the wrong forum. But I believe some answers can be found here because I know canadacow is the one who compiles the dosbox with mt32 emulation built-in. This problem is non-existent on the dosbox w/o mt32 emulation embedded. The graphics are okay on the other dosbox.
Reply 3 of 11, by teamster1975
Aah OK, I didn't realise that it was specific to this version 😜
Reply 4 of 11, by canadacow
Yeah, I really need to post the source. I plan to do so the moment I get a chance. Again, I apologise! (This is what happens when you release software just to avoid it from being considered vaporware.) 😁
Reply 5 of 11, by teamster1975
You don't have to apologise Canadacow! Thankyou for your continued work!! 😁
Matthew
Reply 6 of 11, by Harekiet
Rank DOSBox Author
DOSBox Author
canadacow should ofcourse update his dosbox cvs more often 😀
Reply 7 of 11, by canadacow
That I should. 😁
Reply 8 of 11, by Kaminari
Incidentally I don't have this problem and I'm using the same config file for both CVS and MT-32 versions.
Reply 9 of 11, by robertmo
That is why you don't have such a problem 😉
setting:
aspect=false
solves it
Reply 10 of 11, by Kaminari
Reply 11 of 11, by tordeck
The problems is solved. Thanks.
