Fun with GIFAR (security vulnerability)
First post, by MadHax
So, I was tooling around on a retro gaming imageboard when I was struck with a bit of creative madness: I decided that I wanted to embed a DOS game inside of a PNG, so I could post it to the board and see people's reactions when DOSBox loaded an entire game from a small image.
EXAMPLE IMAGES REDACTED
D/Generation (451 KiB) / Jetfighter II (901 KiB)
The scheme I devised works like this:
• image instructs user to download image and place it in their DOSBox emulation folder
• user is instructed to rename file to .bat and run it
• batch interpreter stumbles across the PNG header with no ill effects, then begins interpreting batch code embedded in a PNG chunk near the beginning of the file
• batch code makes a copy of the file as .com and executes it
• CPU stumbles across the PNG header without any major problems, hits a couple of jump instructions and begins executing x86 code embedded after the batch instructions
• x86 code unpacks PKUNZIP and a ZIP archive containing the game to disk (PKUNZIP embedded after the x86 code, the ZIP near the end of the file)[1]
• batch resumes control, uses PKUNZIP to unpack the ZIP, deletes the temporary files then starts the game
• user is freaked out when they're suddenly playing a game
I realized people would be hesitant about following the instructions, but I intended to justify it with the explanation that since DOSBox is a VM, there was no way it could damage their system. The worst case scenario would be the corruption of their emulation folder, assuming they didn't mount an empty one. It was then that I realized that something like this could wreak havok; there's nothing stopping a batch file from mounting the critical folders on the host system (C:\Windows). From there it would have the same file access privileges as DOSBox itself. With network emulation turned on, all kinds of nastiness could follow.
Thus I'm wondering: wouldn't it be a good idea to have an option to disable disk mounting from batch files, and having that option set by default? There's really no good reason for a batch to be able to do that outside of the autoexec; no legacy program would attempt it, and mounting operations after startup don't really justify automation. Whereas I can see a scenario where someone with malicious intent could trick curious people with the VM excuse to rootkit their systems.
[1] I added an obfuscation step (XOR 0xFF) when the intended imageboard rejected the file for containing an embedded file. It didn't work. I did manage to upload it to half a dozen other imageboards however.
Reply 1 of 25, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It is a security risk but not easily avoided. While you could turn of batch file mounting, one could still add an additional conf file. The autoexec section of that could still automount any folder...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The games you've "wrapped" as examples, are they demos or full commercial versions? The former is probably not a problem, although I think people would be right to be concerned about what kind of Pandora's Box they might be opening; but the latter is not allowed here, in any form.
Reply 3 of 25, by MadHax
Wouldn't that require doing it outside of DOSBox? It would take some major social engineering to get someone to modify their configuration manually -- if you did it with a script or something, you would already be running on the host system and wouldn't have to bother with DOSBox. The devious thing about this exploit is that you have the illusion that DOSBox is a self-contained environment with no access to the host.
They're *mumble mumble*. I removed them.
Reply 4 of 25, by Dominus
DOSBox Moderator
Yeah, I don't exactly understand how your thing works, if the batch is run inside or outside of dosbox. Outside of dosbox you can run any config along with the normal one and the autoexec sections of the configs "stack".
Inside of Dosbox you could also run a little exe with the instructions of the batch, so again I'm not sure how one could prevent this except for a huge blacklist of folders to mount...
Thankfully in modern Windows you normally don't have the rights anymore to mess with critical stuff.
Reply 5 of 25, by NY00123
I don't want to give any promise this is going to make things 100% secure, but at least there are the -noautoexec and -securemode command line arguments (check the DOSBox README for more details).
EDIT: In addition to -securemode, you can still mount some place with the -c argument, say:
dosbox -securemode -c "mount d C:\PATH\TO\SOMEFUN"
But you can't mount new paths within DOSBox.
Reply 6 of 25, by peterferrie
Where's the security vulnerability in this situation? You are requiring the user to *run* something. You don't need all of the fancy obfuscation for that.
The .bat could just about set ACLs and format c:. In any case, DOSBox already contains known vulnerabilities in its handling of certain instructions, which allow it to access OOB memory and potentially run something arbitrary. However, that's not the point.
DOSBox has never been security audited. You play the games, you take your risk. Same as MAME, MESS, and any other emulator.
Reply 7 of 25, by Jorpho
You would almost certainly want to use PKUNZJR.COM, the tiny no-frills version of PKUNZIP.EXE – but I wouldn't be surprised if someone out there hasn't already developed an even tiner version. In fact, for such purposes there's probably someone out there who has made a compression format better than ZIP that requires an even smaller decompression algorithm, but I have no idea what that would be.
There's probably an even more elegant way of doing things – for instance, why not just use a bootable floppy image?
Reply 8 of 25, by leileilol
Not new. I've seen this stegonography method used to sneakily transfer roms over a decade ago.
long live PCem
Reply 9 of 25, by MadHax
For clarification, the .bat runs inside of DOSBox. This is what I consider to be the security issue; ideally, anything inside of a VM should not be able touch anything on the host system beyond what is strictly needed to emulate the VM environment. If someone runs something malicious outside of DOSBox, sucks to be them, there's nothing you can do about it. Yet if I'm playing Super Mario Bros on a NES emulator, I have a reasonable expectation that mario.nes isn't going to be snooping through my documents.
AFAIK it's not possible to mount anything from an executable. An executable would ultimately have to call command.com (or DOSBox's equivalent) to interpret any batch instructions, which I'm guessing would be exactly the same as running a .bat from the command line.
It should still be possible to do something like drop a program in the Windows autorun directory, replace common programs with a trojan, change the Internet browsers' homepage, etc. Many people disable Windows UAC because it's annoying.
I'm glad you pointed these out -- I'm going to add securemode to my sandbox configuration. My argument here is pretty much that this option should be turned on by default. Though like you said, it's a pain not being able to mount stuff manually within DOSBox; every CD-based game would require either its own configuration file or having autoexec mount every ISO on startup. Some method of letting the user manually mount stuff while restricting batch files from doing so would be cleaner.
peterferrie wrote:
You are requiring the user to *run* something...set ACLs and format c:
Addressed at the top of this post. I'm drawing a distinction between running something in DOSBox and running something on the host computer. If something running within DOSBox does something malicious, in the worst case scenario it should corrupt the emulated environment, not run rampant on the host system.
Granted, that's a significant security issue. Yet I'd argue that two wrongs don't make a right -- a person with the same knowledge as me, an understanding of how DOS works and basic DOSBox operation, could exploit the issue I've laid out, whereas that same person would not be able to exploit the OOB overrun without specific knowledge of it.
As an aside, wouldn't Windows Data Execution Prevention prevent this?
I can understand your stance here albeit considering it a mildly unfortunate one. If someone installs malware from an abandonware website, whatever happens to their computer is their own fault, right?
Do you hate spam email? I hate spam email. I also hate it when I'm playing a popular online game and it goes down for hours because some skiddie is DDoSing the server because they have a petty vendetta with an Internet celebrity who happens to be playing the game at the same time. It would be trivial for Internet providers to shut down these fiends if it was just their own computer running from their parents' basements, but it isn't. Spam and DDoS attacks are possible thanks to the millions of zombie systems out there. Those computers are zombies because someone in the household downloaded pirated games from the Internet.
Hundreds of thousands of people use DOSBox. Granted there's nothing you can do to stop the spread of malware in the world, but wouldn't you agree that you have a responsibility to ensure your software isn't contributing to the problem?
Jorpho wrote:
would almost certainly want to use PKUNZJR.COM...why not just use a bootable floppy image?
I went with the path of least resistance; my goal was simply to get the game into a PNG, have instructions simple enough for a 4channer to follow in a 250x250 4bpp image and upload it. I used an ancient copy of PKUNZIP because it's what I had laying around; it was only 29KiB. I agree, my methodology was far from the most elegant.
Reply 10 of 25, by Dominus
DOSBox Moderator
Dosbox just isn't as simple as a condole emulator, not to mention that it doesn't live on piracy like those do.
The only way to make dosbox secure would be to scratch the mount command and only allow imgmount...
Reply 11 of 25, by MadHax
I grabbed the source, it looks like it should be an easy fix. Every time a mount is performed, it checks control->SecureMode() and aborts if it's set. So if SecureMode() had a way to see if it's running as the batch interpreter rather than the command line or autoexec, it could always return true. Currently trying to find the divide between the batch interpreter and command line.
edit:
Okay, so...
control.h
bool SecureMode() const { return secure_mode; }
to
bool SecureMode() {if(RunningFromBatch)return 1;return secure_mode; }
shell_batch.cpp
BatchFile::BatchFile(DOS_Shell * host,char const * const resolved_name,char const * const entered_name, char const * const cmd_line) {
location = 0;
to
RunningFromBatch = 1;
location = 0;
shell_batch.cpp
BatchFile::~BatchFile() {
delete cmd;
to
RunningFromBatch = 0;
delete cmd;
And then RunningFromBatch defined as a bool somewhere. Wouldn't this work?
Reply 12 of 25, by MadHax
That might actually prevent the autoexec from running. Maybe
bool SecureMode() {if(RunningFromBatch&&!first_shell)return 1;return secure_mode; }
instead.
Reply 13 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
MOUNT is implemented as an external program on the Z: drive, not as a shell command. As such it can be executed as a child program and does not necessarily involve the shell or a batch file (although it can by executed that way as well).
That said, I think the question is not how to code it, it's whether or not it's a good idea to rescind long-standing functionality for such an unlikely pathway to attacking a system.
Reply 14 of 25, by MadHax
Easy fix there...restrict anything that's not the shell from touching Z:\MOUNT.COM or Z:\IMGMOUNT.COM. Ints 13h and 21h are handled internally, right?
Like I previously mentioned, there is absolutely no reason for legacy programs, what DOSBox is designed to run, to be mounting drives. The only kind of program that would even be aware of their existence would be one that was specifically designed to be run on DOSBox. The likelihood that this would break anything is much lower than someone finding out about this hole and actively exploiting it.
I don't see an issue with it being an optional thing, like a line in the config file saying letmalwareauthorsrootkitme=false. If someone for whatever reason needs to let software mount stuff from within DOSBox, they just change that one line, and everyone's happy.
Reply 15 of 25, by MadHax
Alright, let me reframe this issue. Let's forget about about files embedded in PNG files and everything like that and look at a hypothetical scenario.
In our hypothetical scenario, I go black hat and inform the security community that DOSBox has a known vulnerability that can be used to rootkit systems (note that I'm not actually threatening to do that). CoD4EvA, a skiddie, reads about the issue. He creates dosabandonware.com and advertises it at online hangouts for teenage gamers. The website claims that the games can't hurt their computers because they're run from inside an emulator, and virus scanners support the claim because they have no idea how to handle DOS programs. The gamers go to dosabandonware.com, download games, and run them in DOSBox.
Obviously these copies of MechWarrior 2 are infected with malware. The moment the kid types "install" a rootkit goes to town on the machine in the background, while MechWarrior runs in the foreground. The parents' credit card numbers are uploaded and backdoor software is downloaded. The machine is now one of many contributing to spam and DDoS attacks.
Wouldn't you consider this a scenario that has a reasonable chance of happening? Is there really any reason to let it happen, however small the chance may be?
Reply 16 of 25, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Well, any blocking is best done within the internal code of MOUNT, it covers all possible avenues (e.g. the internal callback instruction) into MOUNT. Such blocking already exists with securemode, so perhaps the simplest approach is to always use securemode. However, what needs to be considered is how the functionality might be used in existing frontend and menu systems for non-malicious purposes.
Reply 18 of 25, by Jorpho
Why wouldn't the "skiddie" just include the virus as-is? He'd likely lose a big segment of his target audience by expecting them to separately download and configure DOSBox before getting the game running.
There are probably game-console emulators with security flaws in them too.
Also, these statements appear to be contradictory.
Reply 19 of 25, by Dominus
DOSBox Moderator
Btw, anyone disabling UAC AND downloading abandonware has it coming anyway.
Yes, Dosbox is not doing this securely, but this whole thing reminds me of the over protection of children these days.
Anyone wanting to spread trojans or malware or virus can do that much more easily AND reaching many more people by other means.
