First post, by brostenen
Hi all.
After much problem and a lot of mobo's, i finally managed to ret sb16 emulation to work om my sblive.
Now i want to get sound working in dyna blaster.
Was dynablaster sb pro or did it use a specific irq or some special switches when typing Dyna?
I only remember that sound was an issue back then when i wanted sound, and it was indeed working with sb16value wich was a good allround board.
EDIT:
Right... Solved this issue, regarding sound glitches in Dynablaster by a shere mistake in my configuration.
First up. I have disabled any LPT and COM ports, freeing up IRQ 5 and 7.
Next I have installed the SB16 as IRQ7, DMA1 and DMA5, finally the MIDI/MPU set at 300 plus tested with 330.
Now... (running with the SB16 installed)
If I try to use ANY cards at IRQ5, the game will not play sound effects, only music (wich is adlib).
If I try to use ANY cards at DMA3, the result is the same... No sound effects.
If I try to pull this off on any CPU higher than somewere between 200 and 500 mhz, no sound is playing.
Hope this will help anyone, who have had the same problem as I have had.
Note, that this has not been tested with any AWE cards or any PCI based cards, only a standard SB16.
Reply 1 of 7, by brostenen
If anyone will find this usefull, and maby comment on why this is so.
Please do fill in with knowledge.... 😀
Reply 2 of 7, by collector
This should probably be in Marvin. This forum is for DOS games, not hardware and it configuration.
Reply 3 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Moved to Marvin 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 7, by brostenen
You are telling me that a question on how to get a dos game working in dos, are for the Marvin section?
Just qurious because I have had it in dos all this time.
Reply 5 of 7, by Stiletto
Oh, is it this?
http://www.mobygames.com/game/dos/bomberman
Then yeah, probably should be in DOS Games.
do the Fandango!" - Queen
Stiletto
Reply 6 of 7, by brostenen
Stiletto wrote:
Oh, is it this?
Yeah. That's the one.
It's called bomberman on other platforms like gba and such.
It's one of those spinoffs name wise, just like rage racer is to the ridge racer series.
Remember this game as one of the most played in Denmark, back in late 92 or early 93.
The funny thing about this game, is that it's one of those, wich are super picky on hardware
that are faster than Pentium one's rated at 133 or 166 mhz.
It's ment to be running on machines from 386sx's to 486dx2's with SB-Pro or SB-16 card's.
