First post, by MAKOS2148
So hi, until now i just reading a post on this forum but now i made a acc because i need advice. I want to taste old times so i want to bulid a retro pc. I have some ideas but i want to ask someone who are more expirenced than me. So, can you give me some proposition what buy for first time to be satisfied. I want to play games from '92-'93 to '97-'98. And there is one thing: if you want point some shop. they must can ship to Poland (because i life here) and be from EU (becuase i dont want to pay horrible high taxes and transport cost)
Reply 1 of 12, by obobskivich
I'm guessing you'll probably want to look at two machines for such a broad range - I'd assume the later years (like 1998) will be best served by a Pentium 2/3 with a Voodoo3 or TNT2/GeForce running Windows 98 (I'm assuming you want to play games with 3D and the like), while the earlier years will probably get on better with something more like a 486 running DOS.
Reply 2 of 12, by JoeCorrado
Welcome aboard!
Sounds like a nice Windows 95 machine would suit your wishes. You will get great DOS compatibility with the OS and also support for the mid to late nineties games that came after Windows became more mainstream.
There will be plenty of options for your build specs, and you are in the right place to get advice. Just for fun, here is a link to a video that will give you a peak back into the past and the possibilities for your future build.
http://youtu.be/XsZFdFbSzdA
-- Regards, Joe
Expect out of life, that which you put into it.
Reply 3 of 12, by Tr3vor42532
I'd say to get a Pentium 133Mhz to a Pentium MMX 233Mhz machine with about 64MB of ram and a Sound Blaster AWE64, and maybe a 1.5-3GB HDD (preferably Western Digital). Windows 95 is a good OS with these machines.
as far as DOS goes, those computers can pretty much play everything except the most demanding games like Redneck Rampage Rides again, but who cares about that game when you can play Duke 3D.
My YouTube channel: https://www.youtube.com/user/Tr3vor42532
Reply 4 of 12, by bristlehog
That utterly depends on whatever makes you satisfied. However, a simple start for a self-built PC is Pentium II or III - these CPUs are cartridge-based and easy to manipulate. Or, you can buy yourself some complete OEM PC, Pentium or Pentium II/III based, they are generally easier to work with than earlier machines.
Be aware that some later Pentium III motherboards lack ISA slots, that won't suit you if you want sound in DOS games.
I'm gettin' drunk with or without you!
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 5 of 12, by nforce4max
Figuring what sort of system to have in mind is easy but finding everything and get a system working is different. I suggest that you start hunting for parts and existing systems, I don't know how the situation is in your country but start hitting pc shops as well flee markets.
Reply 6 of 12, by PeterLI
Look around in PL for an OEM Pentium machine (75 to 233). Good luck! For the later period games look for a heavy Pentium 2 or regular Pentium 3. 😀
Reply 7 of 12, by Stojke
I started with AMD K6. Id suggest something that can run the video and audio hardware you're interested into at start 😀
Reply 8 of 12, by MAKOS2148
Thx guys for advice, so i try to collect and mayby some day...
Reply 9 of 12, by LunarG
Sounds like a super 7 system would fit this perfectly. A K6-2+ or K6-III perhaps, to have a bit of horsepower for those late 90's games.
Parts are usually easy to find and not too pricey.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 10 of 12, by maximus
If you're just getting into the retro gaming / system building hobby, my suggestion would be to find a complete, working OEM system from whatever period you're most interested in (sounds like that would be Pentium II or III). This should allow you start playing games very quickly, and it would be fairly straightforward to buy parts for your system and upgrade it to the hilt.
Once you're comfortable working with the OEM system, you might start shopping for choice components so you can build a system from scratch. This process can be rewarding, but it can also be a major hassle. If you want to overclock or do other fancy stuff, you have to do it. If you just want to play games, though, OEM will generally be good enough.
PCGames9505
Reply 11 of 12, by badmojo
Lots of different opinions around here as usual! I'd recommend a Windows 98 PIII machine with at least 1 ISA slot. It'll cover just about everything and they're easy to find.
Reply 12 of 12, by triostatis
You should start with 440BX and Pentium III (Katmai would be sufficient) combo, just like other folks suggested. And very easy to find at Polish auction website.
