First post, by Rafael
Hi,
i tried to play x-wing cd-edition, but every time dosbox says: "not enoug memory".
i installed the tool, from which i forgot the name, with which i can rightclick on a file and create a shortcut.
i right-clicked on the file switched to the advance-settings and increased the ems- and xms-memory to 16 mb but nothing changed.
i also installed vsmsound
my machine:
athlon 2600+
512 mb ram
win xp
Reply 1 of 2, by Hazekel
There are two ways to go. The first, and best, is to get the Windows updated version from Lucas Arts. With your old DOS version they allow a trade in for something like $10. They might also have a download patch available if you check their website.
The second method is using DOSBOX and playing with the settings, but I don't know for sure what would work, since I now have the Windows X-Wing. I do have similar problems with Tie Fighter (and haven't yet upgraded) but I have not been able to get that working, so it could be the same boat you are in.
Reply 2 of 2, by taiken7
Try disable EMS (if it can run without it), several games
are reporting not enough (EMS) memory, but run fine without it.
