Asus P5S-VM
First post, by maw
hey,
since the seller on ebay can't ship the board I wanted for my second box (GA-5SMM), I wanted to ask you guys what you think about the Asus P5S-VM > http://h10025.www1.hp.com/ewfrf/wc/document?c … ocname=bph04949
so far what I saw a plus is the capability to be able to disable the onboard VGA. that would save at least 8MB 😀 ...does somebody have experience with that board?
thanks
M.
ASUS P/I-P55T2P4 (REV. 3.10) | Pentium1 233 | 32MB EDO | ATI Rage 128Pro 32mb | 3DFX Diamond Monster 3D | SB 16 CT2230 MT32-PI (DOS/Win3.11) | SB Live CT4760 (Win98) | 8GB Kingspec DOM | CD Drive | Dos 6.22 / Win3.11 + Win98
Reply 1 of 4, by Stojke
I have one board on my AmyBay that can disable onboard VGA - HSING TECH M571.
It supports AMD K6-III where if installed it uses L2 cache as L3 cache. It can overclock the chipset to 83MHz. I also managed to overclock the ISA bus on this board when using an SCSI controller and got speeds of 35MB/s on my hard drives.
Reply 2 of 4, by luckybob
35MB/s on ISA? Surely you jest. To achieve that bandwidth, you would need to run the isa bus @ almost 20mhz, which is more than a 100% overclock from standard.
But to get back on topic, I'd recommend waiting for the board you want. I wouldn't settle for 2nd best in my systems.
Reply 3 of 4, by Stojke
Surely MHDD doesn't lie 😀
Plus proof of performance is windows 95 installation speed and MHDD format/scan speed, as well as classic format command.
Reply 4 of 4, by maw
yes u r right. I thought also since my big box have that board I could use it from there since I really need a micro-atx board for that htpc case I want to use. My big dos-box have enough space for a standard atx sk7 board. hmm hmm hmmm
also thx for the link @Stojke ... I will take a look 😀
M.
