First post, by Stojke
I know Pentium Tualatins have -S to indicate dual processor support, but what about Celerons?
I found these Celerons - http://www.ebay.com/itm/Tualatin-Celeron-1-4G … =item4162404823
Its an OK price for me and i am thinking of abandoning the dual Athlon MP setup (because of so many set backs) and going for dual Slot 1 processor motherboard.
Can any one help me out with info on this?
Reply 2 of 9, by mr_bigmouth_502
I don't think any Celerons support dual-CPU use. Celerons have always been marketed as "budget" processors, and back when the Tualatin was new, dual CPU systems were strictly in the high-end portion of the market, meaning that Intel likely didn't bother to add dual CPU support to their low-end chips.
Reply 3 of 9, by Stojke
I had an Abit Board that supported Dual Celeron processors.
Hmm. I will need to do more research, because i am sure i saw somebody use dual Tualatin Celerons.
Reply 4 of 9, by gerwin
Wikipedia:
Mendocino Socket 370 processors can use multiprocessing when used on specific dual Slot 1 motherboards by using a slot adapter. The unofficial SMP support was removed in the Coppermine Celerons
Reply 6 of 9, by retrofanatic
Stojke wrote:
So, is it possible to run Dual Tualatin Pentium III-S on this board via that special slocket with voltage regulation? […]
[Edit]
Or possibly these??
http://www.ebay.com/itm/Tualatin-P-IIIs-1-4GH … =item417b1c3fc1
A quick search brought up this where a guy mentions it maxed out at (2) 1.1ghz pentium 3 processors:
http://www.tomshardware.com/forum/111490-30-asus
Even with 2x1.1GHz CPU's, you would still have a pretty badass system.
I don't think that the socket adapters will 'override' the actual board's capability, but I of course have not tried it myself, so I am not sure.
The eBay page from your link does not list your motherboard at the bottom of the page as one of the compatible ASUS boards.
Reply 7 of 9, by Stojke
Ive read that there are differences between board revision, where 1.12 is the newest and natively supports voltages for Tualatin.
I have version 1.06. I will try it with an Tualatin 1.3GHz (with power slocket) once it arrives.
[Edit]
A Tualatin is a Tualatin is a Tualatin - if your board can run one, it
can run them all. Perhaps what they are trying to convey is the fact
that 256K Tualatins (both Celeron and PIII) are not dual-processor
capable - only the 512K PIII-S versions support SMP.
> I would wonder if anyone is reporting 1.4G, if they mean that they
> are overclocking a processor to 1.4G.
Dual 1.4Ghz PIII-S on a P2B-DS here - and I don't see my board on the
supported list 😀 I'm running them at stock speed because my current
video card can't handle more than an 89Mhz AGP bus, but the processors
will do 1575Mhz (150Mhz FSB) no problem.
P2B
http://tipperlinne.com/p2bmod
Found some info there.
Reply 8 of 9, by retrofanatic
That's good to hear that it works.
Reply 9 of 9, by Stojke
Since this requires modification of a certain part, what if i used those Tualatins with already installed adapters?
I am not sure how will the voltage variation affect this.
