First post, by Holering
Nobodys' mentioned this so thought I'd post. I'm all for CRTs, but VESA adding native adaptive-sync as the new standard...? That is just way epic! Only way I can think of a CRT with that, is having GPUs interpolate framerate or something. Yeah. It saves energy the lower the framerate btw; as low as static images. How cool is this. Bloody fantastic!
AMD has the follow FAQ:
Q: What is DisplayPort™ Adaptive-Sync?
A: DisplayPort™ Adaptive-Sync is a new addition to the DisplayPort™ 1.2a specification, ported from the embedded DisplayPort™ v1.0 specification. DisplayPort™ Adaptive-Sync provides an industry-standard mechanism that enables real-time adjustment of a monitor’s refresh rate of a display over a DisplayPort™ link.
Q: What is Project FreeSync?
A: Project FreeSync is an AMD effort to leverage industry standards, like DisplayPort™ Adaptive-Sync, to deliver dynamic refresh rates to gamers. Dynamic refresh rates synchronize the refresh rate of a compatible monitor to the framerate of a user’s AMD Radeon™ graphics to reduce or eliminate stuttering, juddering and/or tearing during gaming and video playback.
Q: How are DisplayPort™ Adaptive-Sync and Project FreeSync different?
A: DisplayPort™ Adaptive-Sync is an ingredient DisplayPort™ feature that enables real-time adjustment of monitor refresh rates required by technologies like Project FreeSync. Project FreeSync is a unique AMD hardware/software solution that utilizes DisplayPort™ Adaptive-Sync protocols to enable user-facing benefits: smooth, tearing-free and low-latency gameplay and video.
Q: Is DisplayPort™ Adaptive-Sync the industry-standard version of Project FreeSync?
A: The DisplayPort™ Adaptive-Sync specification was ported from the Embedded DisplayPort™ specification through a proposal to the VESA group by AMD. DisplayPort™ Adaptive-Sync is an ingredient feature of a DisplayPort™ link and an industry standard that enables technologies like Project FreeSync.
Q: What are the requirements to use FreeSync?
A: To use Project FreeSync, users will require: a monitor compatible with DisplayPort™ Adaptive-Sync, a compatible AMD Radeon™ GPU with a DisplayPort™ connection, and a compatible AMD Catalyst™ graphics driver. AMD will release a compatible graphics driver to coincide with the introduction of the first DisplayPort™ Adaptive-Sync monitors.
Q: When can I buy a monitor compatible with Project FreeSync?
A: AMD has undertaken every necessary effort to enable Project FreeSync in the display ecosystem. Monitor vendors are now integrating the DisplayPort™ Adaptive-Sync specification and productizing compatible displays. AMD is working closely with these vendors to bring products to market, and we expect compatible monitors within 6-12 months.
Q: What AMD Radeon™ GPUs are compatible with Project FreeSync?
The first discrete GPUs compatible with Project FreeSync are the AMD Radeon™ R9 290X, R9 290, R7 260X and R7 260 graphics cards. Project FreeSync is also compatible with AMD APUs codenamed “Kabini,” “Temash,” “Beema,” and “Mullins.” All compatible products must be connected via DisplayPort™ to a display that supports DisplayPort™ Adaptive-Sync.
Q: How is Project Freesync different from NVIDIA G-Sync?
While both technologies have similar benefits, G-Sync uses expensive and proprietary hardware. In contrast, Project FreeSync utilizes the industry-standard DisplayPort™ Adaptive-Sync specification to promote wider adoption, lower cost of ownership, and a broad ecosystem of compatibility.
Q: Why should gamers purchase a system that utilizes Project FreeSync?
A: Project FreeSync’s ability to synchronize the refresh rate of a display to the framerate of a graphics card can eliminate visual artifacts that many gamers are especially sensitive to: screen tearing, input lag, and stuttering. Project FreeSync aims to accomplish this through an open ecosystem that does not require licensing fees from participants, which encourages broad adoption and low end-user costs.
Q: What is the supported range of refresh rates with FreeSync and DisplayPort™ Adaptive-Sync?
A: AMD Radeon™ graphics cards will support a wide variety of dynamic refresh ranges with Project FreeSync. Using DisplayPort™ Adaptive-Sync, the graphics card can detect and set an appropriate maximum and minimum refresh rate based on the capabilities reported by the display. Potential ranges include 36-240Hz, 21-144Hz, 17-120Hz and 9-60Hz.
http://www.guru3d.com/news_story/vesa_adds_ad … o_standard.html
I wonder how this'd handle 15khz signals?
EDIT:
After looking at some monitors, I can't seem to find anything over 60hz that doesn't use TV resolution. Actually, even at 60hz, most monitors seem to be just TV's in disguise with no more than 1920x1080 resolution. WTH...? What happened to all the 1900x1200, 1680x1050 and other PC resolutions? Am I seeing $hit? I thought 2560x1440 was common a few years ago. Isn't that what all the rage was with console vs PC gaming; SLI-crossfire gpus for ultra high resolution gaming ...?
EDIT:
Okay I've seen a few 1900x1200s, and a 2880x1620 display, but only a couple at Tigerdirect. Hmmm... Is something going on? Is everyone prepping 144+hz displays at these resolutions? Is it 4K? WTH....?
