First post, by TandySensation
I'm trying to use an Intel P54c with a DFI K6XV3+ Rev A.
The system works perfectly with a AMD K6-200 and K6-2-500 CPU, I have triple boot with 98SE, XP, and Puppy Linux, all work fine.
The problem is when I try to use an Intel Pentium, the system will only post if I don't have anything plugged into the IDE connectors. Even a IDE cable with nothing attached will prevent it from posting/starting, only the fans turn on with no beeps. Unplug the IDE cable and it boots up fine. Tried different cables and different drives attached. Reset the cmos, loaded defaults, removed everything from the board, nothing has worked.
Any suggestions? I wanted to run a p90 and some dos games for nostalgia.
Thanks
