First post, by Coolblue
Hi, I need some help. Recently i've found a downloadable copy of The Logical Journey of the Zoombinis, and I want to play it. The only problem, however, is that the file in question is an ISO file, and not an executable or some other form in which I can run it. Is there a way I could make this file run in DOSBox? Like, can I make some sort of executable file out of it or am I screwed?
Edit: Okay, I got the image found in DOSBox, but now it needs the -size parameters to run it. How do I go about this?
Reply 1 of 3, by Jorpho
Illegal downloads are not supported here.
If you more carefully scrutinize the DOSBox readme, you will find that the -size parameter is not required for ISO images.
Reply 2 of 3, by catchaserguns
Its always good to have the legal copy. That way there is less hassle.
