First post, by soviet conscript
- Oldbie
Ok, this is basically info I recall reading from various sources but I recall reading that a matrox G200 with 16MB or RAM should not be overclocked because there is a bug where if you have 16MB a timing error will occur if you OC. Now the G250 that was an OEM version is slightly factory OCed to 96mhz and If you add the extra RAM I've read two different things. One stated that you will get the timing bug but another online source I read wrote that if you install the 16MB on a g250 it will automatically de-overclock itself back to 84mhz. anyone know? also what is the nature of the bug?
