Reply 19520 of 27471, by brostenen
- l33t++
Been fiddeling with my PiStorm the last two days. Getting to know it. I am just curious as if I have done something wrong. Sysinfo reports A600 ChipSpeed at 2.63!!!! Is that normal, because last reports that I came across, was ChipSpeed at around 0.97 or something like that. And that is from within Workbench and directly from floppy.
Else it is a joy to finally see over 130 megabyte of ram on an Amiga500. Damn that is sweet...
For those that are interrested in my setup. Then I have installed the PiStorm software, installed Midnight Commander as well as enabled root login and set the resolution at 1024x76 in raspi-config. The only two things that I have changed in the PiStorm-Config, are loading Kickstart 3.1 from the SD card and having one single HDF file set up in the SCSI emulator. Else everything is stock (020 and so on)
