What is this SCSI Card?
First post, by brostenen
Someone gave me a load of old hardware, and this card is nowere to be found on IBM's website.
If someone know a place were I can download drivers and/or info, then I would be happy.
I only know, that this is an IBM/Adaptec industry grade SCSI controller from a Server.
Thanks in advance. 😀
Reply 1 of 2, by Stojke
Its an 68pin SCSI raid card.
Reply 2 of 2, by obobskivich
It's a monster. 🤣
It's also out of an IBM, and therefore has an FRU (76H6875), which means it will be easy to find. A quick search and it's an IBM PC ServeRAID Adapter, here's what I found on IBM website (#2 result in Duck Duck Go): http://www-947.ibm.com/support/entry/portal/d … cid=MCGN-44JRJS The diagram looks pretty close. So then "IBM PC ServeRAID Adapter" yields: http://www-2000.ibm.com/partnerworld/ap/kr/ib … k_reference.pdf and the first card pictured looks exactly like what you have; ServeRAID I (70G8489).
I didn't go through their driver download search because I don't know what operating system you want to support, but it shouldn't be terribly hard to find. 😀
