ElectricMonk wrote:Kreshna Aryaguna Nurzaman wrote:ElectricMonk wrote:I apologize for the less than stellar image I uploaded to Imgur, but while in Veinna Sound studio, but do I replace the instruments with the ones I wish from other soundfonts? Or do I also need to replace all the presets as well?
I don't quite remember; it was 2012 when I tinkered with sound fonts. IIRC you just need to replace the instrument number, that' all.
If that's the case, I know what my project this afternoon is! 😀
Use this for reference. For example, the GM instrument number of Trombone is 58. So if you open Bellatrix Orchestra, and see different instrument number for Trombone (let say, 3 or 14, for example), then change it to 58. And so on.
Bellatrix Orchestra is the only sound font in my stack where I need to change instrument numbers, by the way. 😀
ElectricMonk wrote:Did you run across any issues with some instruments from one soundfount being louder than others, or is there a way to normalize them?
But of course! Drums! by Slavo is a notorious example, so I reduced the volume to about 75% or 80% of the original (don't quite remember the exact percentage).
Of all the sound fonts in my stack, only Drums! by Slavo that needs to be reduced in volume, IIRC.
ElectricMonk wrote:I also noticed some people talking about certain emulated synths lacking FX/reverb processing and the like. Think this will be an issue with what I'm trying to do?
Huh? I've never messed around with FX/reverb. All I did was changing the instrument number to make Bellatrix Orchestra adhere to the standard GM instrument number, and reduce the volume of Drums! by Slavo.
Anyway, are you Hz is Good from Techreport forum? If that's the case, then welcome to Vogons. 😀 Yes, I am the Kreshna Aryaguna Nurzaman on TR forum you previously talked to.
(and have you found a pair of JBL 044Tis I'd like to buy? 😉 )
Kreshna Aryaguna Nurzaman.
