First post, by Totempole
- Member
With reference to the above, which would you say is better at factory defaults? A standard Radeon 9500 Pro or a Dell Radeon 9700 TX (Underclocked Radeon 9700)?
Here are the basic specs: Obtained from GPU review and adjusted to correctly reflect the Dell Radeon 9700 TX.
Radeon 9500 Pro
Manufacturer:_______ATi
Series:_____________Radeon 9
GPU:_______________R300
Release Date:_______ 2002-10-24
Interface:__________ AGP 8X
Core Clock:_________ 275 MHz
Memory Clock:_______270 MHz (540 DDR)
Memory Bandwidth:___8.64 GB/sec
Shader Operations:___2200 MOperations/sec
Pixel Fill Rate:_______ 2200 MPixels/sec
Texture Fill Rate:_____2200 MTexels/sec
Vertex Operations:___ 275 MVertices/sec
Dell Radeon 9700 TX
Core Clock:_________ 260 MHz
Memory Clock:_______260 MHz (520 DDR)
Memory Bandwidth:___16.6 GB/sec
Shader Operations:___2080 MOperations/sec
Pixel Fill Rate:_______ 2080 MPixels/sec
Texture Fill Rate:_____2080 MTexels/sec
Vertex Operations:___ 260 MVertices/se
So at first glance, it looks like the 9500 Pro is better, but the Dell 9700 still has double the memory bandwidth, although I'm not sure as to how big of a difference that would make.
What do you guys think?
Thanks.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
