First post, by boxpressed
- Oldbie
I just received a 3D Fuzion GeForce FX 5500 from an eBay seller. When I inspected the card, the fan was clogged with dust, which I removed with compressed air. When I installed and ran the card, it seemed to work properly, except that the onboard fan did not spin up at all. I considered that the fan might activate only when the GPU got hot enough, so I ran a Quake II timedemo. I did not notice any glitching or other abnormalities, and the fan remained off. Could it be possible that Quake II isn't taxing the GPU enough? The fan casing is quite hot to the touch -- Voodoo3 heatsink hot.
It seems odd that the fan should not be running, so I did not do any further testing so as not to damage the GPU.
This is a 256MB PCI card. I have been using a 128MB PNY PCI card (also an FX 5500), but the 3D Fuzion card is almost 10% faster in the Quake II timedemo, so I'd like to use it if possible. Should I run some more benchmarks, or do we know that the fan should always be on? Thanks for your advice.
