First post, by Totempole
- Member
A few years back I bought 3 brand new 15" CRT monitors. I tested them shortly thereafter but only for a few minutes each, then kept them in storage for a few months. Whenn I finally got around to using them, I found that one had a defect.
After about 30 minutes of use, the top right corner of the screen seems to become magnetized and change colour. I.E if you have a red wallpaper, the top right corner fades to violet, then pink and eventually becomes cyan. If you switch the screen off for a few minutes and on again, it corrects itself, but it changes colour again shortly thereafter.
At this stage I'm pretty much just keeping it for spares, since I have no Idea what the cause of the problem is or how to fix it.
Any ideas what the problem could be? I suspect that whatever does the degaussing is faulty, but my knowledge of CRT's is dangerous, and doesn't go much further than internal colour, brightness and focus adjustment.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
