serial port support
First post, by anony
good day guys,
i just want to know if doxbox supports use of serial ports?
thanks,
anony
Reply 2 of 3, by anony
i went to take at the site you gave but there wasn't any clear explanation if serial ports were supported or i was just dumb to not understand what they've talked about. in any case, please enlighten me sir. i need an exact answer to this.
thanks,
anony
Reply 3 of 3, by Fizzban
No, you cannot access the serial ports of your computer with DOSBOX. If you want that, you have to code it yourself.
