First post, by Ridley
Heyyy,
i've recently re-discovered the awesomeness of DOS gaming, hurrah !
Been browsing the forum for a couple of days now and noticed alot of people build there own machines to get the best out of DOS gaming, while i dont think i want to go that far i am willing to buy an older monitor but what im wondering is.... is it easy / worth it to buy an old CRT / TFT monitor and just emulate Dosbox through it? sometimes i think if the pixels were not stretched as much and i was playing it as it was meant to be played, the game would be so much more enjoyable. Just some general guidance or point in the right direction from some of the vets around would be useful or thread to read that i've missed.
Cheers
Ridley
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think you should either go with an old setup with real Dos or just use Dosbox, disable scalers and enjoy it like this. Using an old monitor will IMO only bring grief instead of joy 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 6, by Ridley
hmmm i did briefly try, though the blackness filling up the rest of the screen put me off, maybe i just need to man up and get with the programme. I just thought if i got a daft little monitor it would be simple as pluggin it in, bit of fiddling with settings etc hey presto DOS at its finest on a 17" monitor or something 😜
Reply 3 of 6, by Dominus
DOSBox Moderator
The blackness can be solved differently. Since I didn'tencounter it in the last few years, someone else needs to "fix" that 😉
Reply 4 of 6, by Ridley
the only way i got rid of that was using the scalers, otherwise no idea xD
Reply 5 of 6, by leileilol
A little note that you need at least normal2x on anyway for 320x200/240 to look right. I'ts doublescan and your CRT probably does not support actual 320x200 video modes.
long live PCem
Reply 6 of 6, by marooned_on_mars
I think it might be more of an issue with the video card. I had an old NVidia AGP card that could display those low resolutions properly on my monitor, which in turn made it look authentic.
