First post, by Axel van Haastrecht
I have an old DOS database called FileExpress.
I have that on mij computer in a directory called FE5.
I have mounted that directory in DosBox as follows mount c c:\fe5
With a dir command I can see the files in the directory.
When I start the program it askes for the directory where my files are in, and when I type c:\fe5 it answers that it is an invalid pathname.
What do I do wrong?
Axel van Haastrecht.
Reply 2 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
1.moved to the dosbox forums
2. Collector is right about everything
3. in Dosbox programs can only "see" what has been mounted and subfolders of what has been mounted.
You mounted your real folder c:/fe5 as c. So the correct answer when asked for the files is c:\
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
