First post, by Nahkri
I have this voodoo 3 3000 videocard and it looks slightly different from the original ones,also the sticker says made in china instead of made in mexico as the original,is this a real voodoo 3 or some chinese counterfeit?
http://tdfx.de/eng/voodoo3_3000_agp.shtml
Reply 4 of 6, by raymangold
Nahkri wrote:
Also the heatsink its glued to the chip it doesn't have those 2 bolts.
Well a handful of 3dfx cards were made for the Asian market that weren't released here.
All voodoo3s have the heatsink glued on regardless if they have the through-pin heatsinks or not. The tantalum could be an aftermarket thing or an odd addition to the assembly process. I'm going to say aftermarket as that looks to be a through hole tantalum mounted on surface mount pads...
There are no differences with the PCB however.
So what most likely happened: it was released in Asia and someone decided to replace one of the capacitors.
There are a load of Voodoo 3s (made in mexico) with the same heatsink:
Reply 5 of 6, by GeorgeMan
Nope, I bought two Voodoo3 3000 today, and one of them is exactly like that. With a tantalum and a "china" sticker on it. 😉
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
