First post, by 1ce2go
Hi all. I was wondering if there was a place on this forum where one could find a list of processor benchmarks , perhaps with Norton SI or equivalent, with cache disabled?
It would be helpful to someone like me, trying to build a dos machine to relive my youth after so many years.
- Sean
Reply 1 of 10, by gerwin
What kind of system are you considering?:
Without caches:
Socket 3 486: Slow, depends a lot on the CPU and FSB used, many options...
Socket 5 Pentiums and such: Depends on the FSB options. Talk to Vetz 😉
Socket 7 Pentium MMX, 6x86L, K6 and such: 486-like speeds.
Socket 370/Slot-1 Pentium II/III: 386-like speeds.
Socket 370 VIA C3 Nehemiah: 386 to 486DX-40 speeds (use Setmul).
AMD Athlon and Pentium 4: 486-like speeds.
Without caches one cannot use Sound Blaster emulation on a PCI based soundcard: ISA slot required!
Reply 2 of 10, by 1ce2go
Well like most things I do in life I have just jumped in and Ill see how it goes. I bought a Pentium 100 machine (without monitor) for about a $5 and and dual PII for about $12. Also won a box full of cards along with a 386 sx board for about $2. Sadly, the board doesn't seem to work. The other cards probably do, have only tested the ISA video card and it works. The Pentium works and is immaculate, the PII suddenly started working after two weeks of non stop fiddling and jumper changing etc. I had actually promised myself to give it one last try (for the tenth time), when it suddenly powered up, I still cant say why it decided to work when it did.
I don't have a keyboard to fit the Pentium yet, but I bought the little converter on Ebay. Getting dos onto the SCSI of the PII without a cdrom, usb or any disks was a major headache, but I finanny managed today...have a major headache after 4 days of fiddling with drives to get it working. I've just played my first game of Bubble Bobble in 21 years, and that makes it all worth while 😀
Reply 3 of 10, by Mau1wurf1977
Awwww just saw this thread...
I covered this in a bunch of my videos. But I got so many and haven't put these onto my site for easy access yet so they are all over the place:
Goal: One PC does it all: http://youtu.be/gzxnB2CD6aw
That Pentium is already excellent for your plans 😀
For CD-ROM, memory and mouse drivers + boot menu check out my guide:
http://www.philscomputerlab.com/cd-rom-mouse- … t-up-files.html
My YouTube channel
Reply 4 of 10, by 1ce2go
been using computers since i got my Vic20 in 1981, worked with them most of my life, so I'm okay thanks, but I'm checking out your video anyway 😀
Reply 6 of 10, by dr.zeissler
I am searching for the best Dos-Gaming-Machine for al long time.
Actually I use an K6-III+@FSB66 (133-400Mhz) and deactivate Cpucache (batch) if it runs to fast.
This machine can be used for Dos and for Win95 (3dfx), but not all Dostitles run optimal with this machine.
There are some e.g. Wing-Commander1 that run way to fast.
If I cut this one machine into two, the perhaps I would choose an early Pentium oder 486 with a "turbo-Button"
in order to get a big range of performance-compatibility. On the other hand I will go for a PIII>500 for the 3dfx-gaming.
I did not made the decission yet.
Doc
Reply 7 of 10, by PhilsComputerLab
Wing Commander, is this with L1 AND L2 cache disabled? It should run pretty much perfect to be honest.
What graphics card are you using? Using an ISA card can also act as a brake but isn't ideal if you want to run faster games.
I've done a detailed FSB / Multiplier / Cache review of this CPU here: http://youtu.be/2rPhi9-ILHw?t=6m30s
With L1 and L2 disabled I got a 3dbench score of around 11 which is perfect for Wing Commander. Almost a bit too slow.
Reply 8 of 10, by dr.zeissler
i hate solvings that are "not on-the-fly" so I only use "cpucache.com" an fsb66 with multi 2.
deactivating L1 and L2 needs a reboot and Bios-change, and another reboot for activating both.
I think it is better to go for an other machine with a better concept...
Reply 9 of 10, by PhilsComputerLab
That's just being lazy 🤣 A reboot takes like less than a minute.
As for a machine with a better concept: I don't think there is one. Well, DOSBox maybe.
Reply 10 of 10, by squareguy
Wouldn't setmul allow you to change the multiplier, L1 and L2 caches without a reboot on a K6-2+/K6-3+? Pretty sure I can do that.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
