First post, by Vishnu18
Hi.
I recently installed dosbox 0.74 from its official site and installed it on my dell notebook win 8.1 64 bit.
I installed it successfully but found an unusual problem. Whenever i run it, it gets crashed as soon as it opens i.e. Opens just for a split second and gets closed but when i plug in an optical mouse and then run dosbox it works like charm.
I don't know the exact problem and solution to make it run without the mouse plugged.
Help please. I don't want mouse always plugged to make it run and need a permanent solution of such situation.
Thanking You.
