First post, by Subjunctive
- Newbie
I just picked up a Gravis GamePad Pro and am hoping to use it with Jazz Jackrabbit. The machine I'm working with is a P133 with a GUS Classic installed, running DOS 6.22. The GUS itself is fine - Jazz's music and sound both play perfectly - but it refuses to recognize the GamePad Pro. I go to joystick configuration in the menu and it acts like it's not there.
From what I've found, I shouldn't need any actual DOS drivers for this thing - the game supports it natively and should simply detect it. Do I need to do something else? Or would some hardware fault be to blame?
Appreciate any help!
