First post, by Harbinger
Hello guys!
I used DOSbox for many times in the past, never had any problems. Dont know why, but i uninstalled it from my computer some time ago(dont even remember why and when it happend). Today i downloaded 0.74 from this website and installed it. And this time problem occurs. When i start program i get two windows, one of them is black, and another one is with following text(on screenshot). After several seconds both windows close.
[img=http://s24.postimg.org/3jqwu452p/DOSbox_Problem.jpg]
PS i have windows 7
Reply 1 of 2, by ripa
Your config file contents are incorrect. Use the Dosbox->Options "Reset Options" start menu item or fix the config file manually.
Reply 2 of 2, by IIGS_User
Happens to me sometimes as well, when I use a language file.
Try to disable the language file. If it works without, the language file is incorrect.
Klimawandel.
