First post, by tranh2
Hello,
I just recently installed DOSBOX on both a linux (linux mint) machine and a windows 7 machine to test on both. I have a USB to Serial cable and I've been searching and reading. I have edited the dosbox.conf file for the serial1 line. So it is serial1=directserial realport: xxxx where xxxx=Com1 for Windows and xxxx=ttyUSB0 for Linux.
When I startup dosbox through the terminal one of the lines says "Serial1: Opening ttyUSB0" then dosbox opens up in another window. I try to run my program and communicate through the usb-serial and it doesnt look like its communicating. It looks like i'm sending data but i'm not reading data. I say this because the software i'm using has a xmit line and it is constantly incrementing. but recieve lines shows 0bytes received.
I have portmon installed on the windows machine to monitor the port and all I ever see are attempts to read. I never see any attempts to write even when the software shows that data is being sent.
There's definitly nothgin wrong with the cable because I can run hyperterminal and communicate with AT commands to a modem just fine.
Seems like communicating through dosbox does not work.
"Serial1: Opening ttyUSB0" <-- should this say openED instead of openING?
Not sure...Any ideas/help?
