First post, by sapator
sapator
Offline
Hello. I am trying to use a sppedlink usb joystick with sensible soccer, however no mater what i do it will not work.
I can go to the install.exe and setup the joystick just fine but after that when i go to the game the only thing that works is the button1. No movement.
I have also tried wing commander 1 to see if it is a joystick issues but there, it works fine.
Can you please help me?
Thanks.
P.S. i've also set timed = true,false on the config and i see that the joystick is recognized in the dosbox information panel.
