First post, by serrith
Lo everyone,
I recently bought One unit whole Blood from GOG and the game works in dosbox.
However i also use 2 hardware modules i bought a while ago, a Roland MT-32 (first gen) and a Roland SC-8850.
The Roland SC-8850 works perfectly with the SC-55 map in all the games i tried, but when blood starts it displays a message on the SC-8850 that it hasn't got the instrument and the midi plays completely wrong. If i try it with the other maps (8850 / 88PRO / 88 / 55) it gives the same message and plays the midi wrong.
With my original Blood (without expansion and not GOG) it plays correctly.
I made sure the setup points to the roland soundcanvas or just plain general midi and both give the same wrong results.
Other Build games like shadow warrior and duke nukem 3D work flawlessly with it.
Does anyone know what causes it ? I tried max cycles/fixed/low cycles, dynamic processor, normal etc ...
Any help is welcome.
Reply 2 of 7, by serrith
The same, its completely wrong when i select the soundcanvas or the general midi device.
The default midi device is the Roland UM-ONE (it is connected to the Roland SoundCanvas and is a USB-MIDI converter device.)
I do not think that would be the problem since every other game sounds correct.
Reply 3 of 7, by serrith
Oh, i just realised i posted in the wrong board.
Feel free to remove this post/conversation, i'll create it new in the dosbox games forum.
Reply 4 of 7, by adilmalik
I haven't looked into aftermarket memory managers like 386MAX or QEMM because I heard many games are not compatible - can somebody provide comment on this?
adil
Reply 5 of 7, by Mau1wurf1977
There should be zero need for after market managers. You could try my start-up files with CD-ROM and mouse drives. It has 6 boot options to cater for most situations. I'd say 99% of games should work including trickier games like Ultima 7.
My YouTube channel
Reply 6 of 7, by keropi
it could worth a shot to try tilakat's patch here: Re: Apogee / 3D Realms - sound driver hacking
Reply 7 of 7, by filipetolhuizen
You may have to edit DOS Box config file. Try setting mpu401 to intelligent.
