alone in the dark 3 help
First post, by snowboard71
hi,alone in the dark3 dont work,even if i launch it from cd or install it.it says me the same error: file-01:error file not found!!.please someone help me im a newbye.thank you very much
Reply 1 of 3, by eL_PuSHeR
What have you tried so far? VDMSound? DOXBOX? specs? Operating System?
Reply 2 of 3, by snowboard71
ok sorry.i have pentium4 2ghz 256megs ram using dosbox 0.60 in windows 98se.the message error is the sequent:file-01 error file not found indark3.cfg.i have tried to launch it from hdisk and from cd,it give me the same error.my hdisk is c: and my cdrom is d:.ihave done this operations:mount c c:\ mount d d:\.at this point i have installed the game in c\indark.then tryed to launch it with the only.exe command(aitd3.exe).but the error is occurred.can someone reply me step by step i have to do for the game work properly?thanks very much.
Reply 3 of 3, by Snover
Did you run the game's configurator?
edit: When you get something working write it in the thread you were having the problem in, not a second one. 😒
Yes, it’s my fault.
